Timed Negotiations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Timed Negotiations
Negotiations were introduced in [6] as a model for concurrent systems with multiparty decisions. What is very appealing with negotiations is that it is one of the very few non-trivial concurrent models where several interesting problems, such as soundness, i.e. absence of deadlocks, can be solved in PTIME [2]. In this paper, we introduce the model of timed negotiations and consider the problem of computing the minimum and the maximum execution time of a negotiation. The latter can be solved using the algorithm of [10] computing costs in negotiations, but surprisingly minimum execution time cannot. In this paper, we propose new algorithms to compute both minimum and maximum execution time, that work in much more general classes of negotiations than [10], that only considered sound and deterministic negotiations. Further, we uncover the precise complexities of these questions, ranging from PTIME to Delta-2^P-complete. In particular, we show that computing the minimum execution time is more complex than computing the maximum execution time in most classes of negotiations we consider.
TimedNegotiations(Submitted).pdf (550.31 Ko) Télécharger le fichier
hal-02337887 , version 1 (29-10-2019)
  • HAL Id : hal-02337887 , version 1
Sundararaman Akshay, Blaise Genest, Loïc Hélouët, Sharvik Mital. Timed Negotiations. 2019. ⟨hal-02337887⟩
108 Consultations
90 Téléchargements
