On the solution-space geometry of random constraint satisfaction problems, Random Structures & Algorithms, vol.38, issue.3, pp.251-268, 2011. ,
An event stream driven approximation for the analysis of real-time systems, Proc. 16th Euromicro Conf. on Real-Time Systems, pp.187-195, 2004. ,
Scheduling constraineddeadline parallel tasks on two-type heterogeneous multiprocessors, Proc. 24th Int. Conf. on Real-Time Networks, pp.247-256, 2016. ,
Partitioned scheduling of sporadic task systems: an ILP-based approach, Proc. 2008 Conference on Design and Architectures for Signal and Image Processing, 2008. ,
Preemptively scheduling hard-real-time sporadic tasks on one processor, Proc. 11th Real-Time Systems Symposium, pp.182-190, 1990. ,
The partitioned multiprocessor scheduling of deadline-constrained sporadic task systems, IEEE Transactions on Computers, vol.55, issue.7, pp.918-923, 2006. ,
Measuring the performance of schedulability tests. Real-Time Systems, vol.30, pp.129-154, 2005. ,
Algorithms for hierarchical and semi-partitioned machine ,
, 31st Int. Parallel and Distributed Processing Symposium (IPDPS 2017)
Resource augmentation for uniprocessor and multiprocessor partitioned scheduling of sporadic real-time tasks, Real-Time Systems, vol.49, issue.4, pp.475-516, 2013. ,
Optimal real-time scheduling on two-type heterogeneous multicore platforms, Proc. Real-Time Systems Symposium, 2015. ,
Control robotics : the procedural control of physical processors, Proceedings of the IFIP Congress, pp.807-813, 1974. ,
An application of simultaneous diophantine approximation in combinatorial optimization, Combinatorica, vol.7, issue.1, pp.49-65, 1987. ,
A sufficient condition for backtrackbounded search, J. ACM, vol.32, issue.4, pp.755-761, 1985. ,
Unrelated parallel machine schedulingperspectives and progress, OPSEARCH, vol.48, issue.4, pp.318-334, 2011. ,
Reducibility among combinatorial problems, Complexity of Computer Computations, pp.85-103, 1972. ,
, Global wire routing in two-dimensional arrays. Algorithmica, vol.2, pp.113-129, 1987.
Iterative Methods in Combinatorial Optimization, 2011. ,
Approximation algorithms for scheduling unrelated parallel machines, Mathematical Programming, vol.46, pp.259-271, 1990. ,
Scheduling algorithms for multiprogramming in a hard real-time environment, Journal of the ACM, vol.20, issue.1, pp.46-61, 1973. ,
Assigning sporadic tasks to unrelated machines, Mathematical Programming, pp.1-28, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01249101
Real-Time Scheduling on Heterogeneous Multiprocessors, 2014. ,
Assigning real-time tasks on heterogeneous multiprocessors with two unrelated types of processors. Real-Time Systems, vol.49, pp.29-72, 2013. ,
Task assignment algorithms for two-type heterogeneous multiprocessors. Real-Time Systems, vol.50, pp.87-141, 2013. ,
A PTAS for assigning sporadic tasks on two-type heterogeneous multiprocessors, Proc. 33rd Real-Time Systems Symposium, pp.117-126, 2012. ,
An approximation algorithm for the generalized assignment problem, Mathematical Programming, vol.62, pp.461-474, 1993. ,
Partitioned EDF scheduling on a few types of unrelated multiprocessors. Real-Time Systems, vol.49, pp.219-238, 2013. ,
