Cooperative localization for autonomous underwater vehicles. The Int, Journal of Robotics Research, vol.28, issue.6, pp.714-728, 2009. ,
Revising hull and box consistency, Int. Conf. on Logic Programming, pp.230-244, 1999. ,
Cooperative localization of underwater robots with unsynchronized clocks. Paladyn, Journal of Behavioral Robotics, vol.4, issue.4, pp.233-244, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00989590
Mixed-initiative planning and execution for multiple drones in search and rescue missions, Twenty-Fifth International Conference on Automated Planning and Scheduling, pp.315-323, 2015. ,
A bounded uncertainty approach to cooperative localization using relative bearing constraints, IEEE/RSJ International Conference on Intelligent Robots and Systems, pp.2500-2506, 2007. ,
Contractor programming. Artificial Intelligence, vol.173, pp.1079-1100, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00428957
Mobile robot localization by multiangulation using set inversion, Robotics and Autonomous Systems, vol.61, issue.1, pp.39-48, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00735223
Applying cooperative localization to swarm UAVs using an extended Kalman filter, 2014. ,
Localization confidence domains via set inversion on short-term trajectory, IEEE Trans. on Robotics, vol.29, issue.5, pp.1244-1256, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877443
Distributed multirobot exploration and mapping, Proceedings of the IEEE, vol.94, issue.7, pp.1325-1339, 2006. ,
The flying hand: A formation of UAVs for cooperative aerial tele-manipulation, 2014 IEEE International Conference on Robotics and Automation (ICRA), pp.4335-4341, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01990572
Observability-based consistent EKF estimators for multi-robot cooperative localization, Autonomous Robots, vol.30, issue.1, pp.99-122, 2011. ,
Set inversion via interval analysis for nonlinear bounded-error estimation, Automatica, vol.29, issue.4, pp.90106-90110, 1993. ,
Applied interval analysis: with examples in parameter and state estimation, robust control and robotics, 2001. ,
URL : https://hal.archives-ouvertes.fr/hal-00845131
Shared-control for a UAV operating in the 3D space, European Control Conference (ECC), pp.1633-1638, 2015. ,
Image-based UAV localization using interval methods, 2017 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.5285-5291, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01572369
Cooperative localization with reliable confidence domains between vehicles sharing GNSS pseudoranges errors with no base station, IEEE Intelligent Transportation Systems Magazine, vol.9, issue.1, pp.22-34, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01390329
Multiple UAV cooperative searching operation using polygon area decomposition and efficient coverage algorithms, Distributed Autonomous Robotic Systems, vol.6, pp.221-230, 2007. ,
A box regularized particle filter for terrain navigation with highly non-linear measurements, 20th IFAC Symposium on Automatic Control in Aerospace (ACA 2016), vol.49, pp.361-366, 2016. ,
Cooperative manipulation and transportation with aerial robots, Autonomous Robots, vol.30, issue.1, pp.73-86, 2011. ,
Interval analysis, 1966. ,
Cooperative localization against gps signal loss in multiple uavs flight, Journal of Systems Engineering and Electronics, vol.22, issue.1, pp.103-112, 2011. ,
Distributed multirobot localization, IEEE Transactions on Robotics and Automation, vol.18, issue.5, pp.781-795, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00428663
Ranging in the IEEE 802.15.4a standard, IEEE Annual Wireless and Microwave Technology Conference, pp.1-5, 2006. ,
Bearing rigidity maintenance for formations of quadrotor UAVs, ICRA 2017 -IEEE Int. Conf. on Robotics and Automation, pp.1467-1474, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01482422
A bounded uncertainty approach to multi-robot localization, Proceedings 2003 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2003), vol.2, pp.1258-1264, 2003. ,
General decentralized data fusion with covariance intersection, Handbook of Multisensor Data Fusion, pp.319-343, 2008. ,
AprilTag 2: Efficient and robust fiducial detection, IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.4193-4198, 2016. ,
