ODE-based Double-preconditioning for Solving Linear Systems $A^{\alpha}x = b$ and $f(A)x=b$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Linear Algebra with Applications Année : 2021
This paper is devoted to the computation of the solution to fractional linear algebraic systems using a differential-based strategy to evaluate matrix-vector products $A^\alpha x$, with $\alpha \in \mathbb{R}^{*}_{+}$. More specifically, we propose ODE-based preconditioners for efficiently solving fractional linear systems in combination with traditional sparse linear system preconditioners. Different types of preconditioners are derived (Jacobi, Incomplete LU, Padé) and numerically compared. The extension to systems $f (A)x = b$ is finally considered.
ode.pdf (2.67 Mo) Télécharger le fichier
hal-02340590 , version 1 (30-10-2019)
Xavier Antoine, Emmanuel Lorin. ODE-based Double-preconditioning for Solving Linear Systems $A^{\alpha}x = b$ and $f(A)x=b$. Numerical Linear Algebra with Applications, 2021, ⟨10.1002/nla.2399⟩. ⟨hal-02340590⟩
69 Consultations
66 Téléchargements
