A variational discrete element method for quasi-static and dynamic elasto-plasticity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Engineering Année : 2020
We propose a new discrete element method supporting general polyhedral meshes. The method can be understood as a lowest-order discontinuous Galerkin method parametrized by the continuous mechanical parameters (Young's modulus and Poisson's ratio). We consider quasi-static and dynamic elasto-plasticity, and in the latter situation, a pseudo-energy conserving time-integration method is employed. The computational cost of the time-stepping method is moderate since it is explicit and used with a naturally diagonal mass matrix. Numerical examples are presented to illustrate the robustness and versatility of the method for quasi-static and dynamic elasto-plastic evolutions.
dem.pdf (7.81 Mo) Télécharger le fichier
hal-02343280 , version 1 (02-11-2019)
hal-02343280 , version 2 (04-11-2019)
hal-02343280 , version 3 (12-11-2019)
hal-02343280 , version 4 (13-04-2020)
hal-02343280 , version 5 (01-06-2020)
Frédéric Marazzato, Alexandre Ern, Laurent Monasse. A variational discrete element method for quasi-static and dynamic elasto-plasticity. International Journal for Numerical Methods in Engineering, In press, ⟨10.1002/nme.6460⟩. ⟨hal-02343280v5⟩
338 Consultations
148 Téléchargements
