A GenEO Domain Decomposition method for Saddle Point problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We introduce an adaptive element-based domain decomposition (DD) method for solving saddle point problems defined as a block two by two matrix. The algorithm does not require any knowledge of the constrained space. We assume that all sub matrices are sparse and that the diagonal blocks are spectrally equivalent to a sum of positive semi definite matrices. The latter assumption enables the design of adaptive coarse space for DD methods that extends the GenEO theory to saddle point problems. Numerical results on three dimensional elasticity problems for steel-rubber structures discretized by a finite element with continuous pressure are shown for up to one billion degrees of freedom.
schurcomplement.pdf (549.2 Ko) Télécharger le fichier
hal-02343808 , version 1 (04-11-2019)
hal-02343808 , version 2 (14-11-2019)
hal-02343808 , version 3 (19-03-2020)
hal-02343808 , version 4 (26-04-2021)
hal-02343808 , version 5 (21-12-2021)
hal-02343808 , version 6 (16-11-2022)
Frédéric Nataf, Pierre-Henri Tournier. A GenEO Domain Decomposition method for Saddle Point problems. 2021. ⟨hal-02343808v4⟩
285 Consultations
318 Téléchargements
