Distance between extremum graphs, PacificVis, 2015. ,
Efficient computation of the tree edit distance, ACM Trans. Database Syst, 2015. ,
On-demand augmentation of contour trees, 2018. ,
Edit distance between merge trees, IEEE TVCG, 2020. ,
Streak lines as tangent curves of a derived vector field, IEEE TVCG, 2010. ,
