Automatic Non-manifold Topology Recovery and Geometry Noise Removal, pp.267-279, 2009. ,
Surface meshing using vertex insertion, Proceedings of the 5th International Meshing Roundtable, pp.243-256, 1996. ,
Advancing front surface mesh generation in parametric space using a riemannian surface definition, Proceedings of the 7th International Meshing Roundtable, 1998. ,
Mesh generation on high-curvature surfaces based on a background quadtree structure, Proceedings of the 11th International Meshing Roundtable, 2002. ,
EQSM: An efficient high quality surface grid generation method based on remeshing, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.41, pp.5621-5633, 2006. ,
Some aspects of parametric surface meshing, Finite Elements in Analysis and Design, vol.46, pp.216-226, 2010. ,
A Hierarchical Adaptive Mesh Generation Strategy for Parametric Surfaces Based on Tree Structures, 23rd SIBGRAPI Conference on Graphics, Patterns and Images, pp.79-86, 2010. ,
An Adaptive Parametric Surface Mesh Generation Method Guided by Curvatures, Proceedings of the 22nd International Meshing Roundtable, 2014. ,
A robust conforming NURBS tessellation for industrial applications based on a mesh generation approach, Computer-Aided Design, vol.63, pp.26-38, 2015. ,
Maillage de surfaces paramétriques. Partie I: Aspects théoriques, vol.INRIA, 1996. ,
Optimizing the geometrical accuracy of curvilinear meshes, Journal of Computational Physics, vol.310, pp.361-380, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01299472
Defining an L 2 -disparity Measure to Check and Improve the Geometric Accuracy of Non-interpolating Curved High-order Meshes, Procedia Engineering, vol.124, pp.122-134, 2015. ,
High-order mesh curving by distortion minimization with boundary nodes free to slide on a 3D CAD representation, 23rd International Meshing Roundtable Special Issue: Advances in Mesh Generation, vol.72, pp.52-64, 2016. ,
Generation of curved high-order meshes with optimal quality and geometric accuracy, Procedia engineering, vol.163, pp.315-327, 2016. ,
High-order mesh generation for CFD solvers, Imperial College, 2018. ,
A distortion measure to validate and generate curved high-order meshes on CAD surfaces with independence of parameterization, International Journal for Numerical Methods in Engineering, vol.106, issue.13, pp.1100-1130, 2016. ,
Very High Order Anisotropic Metric-Based Mesh Adaptation in 3D, Procedia Engineering, vol.163, pp.353-364, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01438226
Continuous mesh framework part I: well-posed continuous interpolation error, SIAM J. Numer. Anal, vol.49, issue.1, pp.38-60, 2011. ,
Continuous mesh framework part II: validations and applications, SIAM J. Numer. Anal, vol.49, issue.1, pp.61-86, 2011. ,
Linear Programming 2: Theory and Extensions, 2003. ,
Differential Geometry of Curves and Surfaces: Revised and Updated Second Edition, Courier, 2016. ,
About surface remeshing, Proceedings of the 9th international meshing roundtable, 2000. ,
, Geometric Modeling and Numerical Simulation 2: Metrics, Meshes and Mesh Adaptation, 2019.
Note sur une nouvelle formule de calcul différentiel, Quarterly J. Pure Appl. Math, vol.1, issue.359, p.1857 ,
A short proof of the generalized Faà di Bruno's formula, Applied mathematics letters, vol.16, issue.6, pp.975-979, 2003. ,
On The Construction of Aircraft Conceptual Geometry for High-Fidelity Analysis and Design, 50th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, 2012. ,
Delaunay triangulation and meshing, Hermes, 1998. ,
Vizir: High-order mesh and solution visualization using OpenGL 4.0 graphic pipeline, AIAA Aerospace Sciences Meeting, pp.2018-1174, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01686714
