Effect of free rotation on the motion of a solid sphere in linear shear flow at moderate Re, Phys. Fluids, vol.14, issue.8, pp.2719-2737, 2002. ,
A sphere in a uniformly rotating or shearing flow, J. Fluid Mech, vol.600, pp.201-233, 2008. ,
Drag and lift forces on particles in a rotating flow, J. Fluid Mech, vol.643, pp.1-31, 2010. ,
, Bubbles, Drops and Particles. Academic, 1978.
The rise velocity and shape of bubbles in pure water at high Reynolds number, J. Fluid Mech, vol.292, pp.325-332, 1995. ,
Bubble Wake Dynamics in Liquids and Liquid-Solid Suspensions, 1990. ,
Wake structure of a transversely rotating sphere at moderate Reynolds numbers, J. Fluid Mech, vol.621, pp.103-130, 2009. ,
Flow past a sphere up to a Reynolds number of 300, J. Fluid Mech, vol.378, pp.19-70, 1999. ,
Laminar flow past a sphere rotating in the transverse direction, J. Mech. Sci. Technol, vol.23, pp.578-589, 2009. ,
Drag and lift forces on a rotating sphere in a linear shear flow, J. Fluid Mech, vol.384, pp.183-206, 1999. ,
Steady wake behind a sphere, Phys. Fluids, vol.19, pp.5-8, 1976. ,
Laminar flow structures from a rotating sphere: effect of rotating axis angle, Intl J. Heat Fluid Flow, vol.31, pp.961-972, 2010. ,
Hydrodynamic forces on a rotating sphere, Intl J. Heat Fluid Flow, vol.42, pp.278-288, 2013. ,
Flow past a transversely rotating sphere at Reynolds numbers above the laminar regime, J. Fluid Mech, vol.759, pp.751-781, 2014. ,
Drag and lift forces on interfacecontaminated bubbles spinning in a rotating flow, J. Fluid Mech, vol.624, pp.159-178, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00405326
Drag and lift forces on clean spherical and ellipsoidal bubbles in a solid-body rotating flow, J. Fluid Mech, vol.682, pp.434-459, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00620819
Clean versus contaminated bubbles in a solid-body rotating flow, J. Fluid Mech, vol.831, pp.529-617, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01627320
Agitation, mixing, and transfers induced by bubbles, Annu. Rev. Fluid Mech, vol.50, pp.25-48, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01778999
Experimental investigation of the wake behind a sphere at low Reynolds, J. Phys. Soc. Japan, vol.11, pp.1104-1108, 1956. ,
Numerical investigation of transition and weak turbulent flow past a sphere, J. Fluid Mech, vol.416, pp.45-73, 2000. ,
