Analyzing global-EDF for multiprocessor scheduling of parallel tasks, Proceedings of the 16th International Conference on Principles of Distributed Systems, pp.16-30, 2012. ,
Schedulability analysis of multiprocessor sporadic task systems, Handbook of Real-Time and Embedded Systems, 2007. ,
A general model for recurring real-time tasks, Proceedings of the Real-Time Systems Symposium, pp.114-122, 1998. ,
Improved multiprocessor global schedulability analysis. Real-Time Syst, vol.46, pp.3-24, 2010. ,
A constant-approximate feasibility test for multiprocessor real-time scheduling, Algorithmica, vol.62, pp.1034-1049, 2012. ,
Control robotics: The procedural control of physical processes, Proceedings of the International Federation for Information Processing Congress, pp.807-813, 1974. ,
EDF-schedulability of synchronous periodic task systems is coNP-hard, Proceedings of the 21st Symposium on Discrete Algorithms, Moses Charikar, pp.1029-1034, 2010. ,
A multi-DAG model for real-time parallel applications with conditional execution, Proceedings of the ACM/ SIGAPP Symposium on Applied Computing (SAC'15), pp.1925-1932, 2015. ,
Computers and Intractability: A Guide to the Theory of NP-Completeness, 1979. ,
Optimization and approximation in deterministic sequencing and scheduling: A survey, Ann. Discr. Math, vol.5, pp.287-326, 1979. ,
Scheduling parallel real-time tasks on multi-core processors, Proceedings of the IEEE Real-Time Systems Symposium, pp.259-268, 2010. ,
Complexity of scheduling under precedence constraints, Operat. Res, vol.26, pp.22-35, 1978. ,
A note on preemptive scheduling of periodic, real-time tasks, Inf. Process. Lett, vol.11, pp.115-118, 1980. ,
On the complexity of fixed-priority scheduling of periodic, real-time tasks, Perform. Eval, vol.2, pp.237-250, 1982. ,
Analysis of global EDF for parallel tasks, Proceedings of the Euromicro Conference on Real-Time Systems, pp.3-13, 2013. ,
Analysis of federated and global scheduling for parallel real-time tasks, Proceedings of the Euromicro Conference on Real-Time Systems, pp.85-96, 2014. ,
Global EDF scheduling for parallel real-time tasks, Real-Time Syst, vol.51, pp.395-439, 2015. ,
Scheduling algorithms for hard real-time programming of a single processor, JPL Space Progr. Sum. 37, vol.60, pp.31-37, 1969. ,
Scheduling algorithms for multiprocessors in a hard real-time environment, JPL Space Progr. Sum. 37, vol.60, pp.28-31, 1969. ,
Scheduling algorithms for multiprogramming in a hard-real-time environment, J. ACM, vol.20, pp.46-61, 1973. ,
Fundamental Fesign Problems of Distributed Systems for the Hard Real-time Environment, 1983. ,
Techniques optimizing the number of processors to schedule multi-threaded tasks, Proceedings of the Euromicro Conference on Real-Time Systems, pp.321-330, 2012. ,
Optimal time-critical scheduling via resource augmentation, Algorithmica, vol.32, pp.163-200, 2002. ,
Parallel real-time scheduling of DAGs, IEEE Trans. Parallel Distrib. Syst, vol.25, pp.3242-3252, 2014. ,
Multi-core real-time scheduling for generalized parallel task models. Real-Time Syst, vol.49, pp.404-435, 2013. ,
The digraph real-time task model, Proceedings of the IEEE Real-Time and Embedded Technology and Applications Symposium, pp.71-80, 2011. ,
NP-complete scheduling problems, J. Comput. Syst. Sci, vol.10, pp.384-393, 1975. ,
