Optimal Actuation of Flagellar Magnetic Micro-Swimmers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E : Statistical, Nonlinear, and Soft Matter Physics Année : 2020
We present an automated procedure for the design of optimal actuation for flagellar magnetic microswimmers based on numerical optimization. Using this method, a new magnetic actuation method is provided which allows these devices to swim significantly faster compared to the usual sinusoidal actuation. This leads to a novel swimming strategy which makes the swimmer perform a 3D figure-8 trajectory. This shows that a faster propulsion is obtained when the swimmer is allowed to go out-of-plane. This approach is experimentally validated on a scaled-up flexible swimmer.
root.pdf (1.1 Mo) Télécharger le fichier
hal-02350868 , version 1 (07-11-2019)
hal-02350868 , version 2 (28-10-2020)
Yacine El Alaoui-Faris, Jean-Baptiste Pomet, Stéphane Régnier, Laetitia Giraldi. Optimal Actuation of Flagellar Magnetic Micro-Swimmers. Physical Review E : Statistical, Nonlinear, and Soft Matter Physics, 2020, ⟨10.1103/PhysRevE.101.042604⟩. ⟨hal-02350868v2⟩
231 Consultations
408 Téléchargements
