Secure Firmware Updates for Constrained IoT Devices Using Open Standards: A Reality Check - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2019
While IoT deployments multiply in a wide variety of verticals, most IoT devices lack a built-in secure firmware update mechanism. Without such a mechanism, however, critical security vulnerabilities cannot be fixed, and IoT devices can become a permanent liability , as demonstrated by recent large-scale attacks. In this paper, we survey open standards and open source libraries that provide useful building blocks for secure firmware updates for constrained IoT devices -- by which we mean low-power, microcontroller-based devices such as networked sensors/actuators with a small amount of memory, among other constraints. We design and implement a prototype that leverages these building blocks and assess the security properties of this prototype. We present experimental results , including first experiments with SUIT, a new IETF standard for secure IoT firmware updates. We evaluate the performance of our implementation on a variety of commercial off-the-shelf constrained IoT devices. We conclude that it is possible to create a secure, standards-compliant firmware update solution that uses state-of-the-art security for IoT devices with less than 32kB of RAM and 128kB of flash memory.
HAL-version.pdf (4.23 Mo) Télécharger le fichier
hal-02351794 , version 1 (06-11-2019)
Koen Zandberg, Kaspar Schleiser, Francisco Acosta, Hannes Tschofenig, Emmanuel Baccelli. Secure Firmware Updates for Constrained IoT Devices Using Open Standards: A Reality Check. IEEE Access, 2019, 7, pp.71907-71920. ⟨10.1109/ACCESS.2019.2919760⟩. ⟨hal-02351794⟩
226 Consultations
1514 Téléchargements
