pgmpy: Probabilistic graphical models using python, Proceedings of the 14th Python in Science Conference (SCIPY 2015), 2015. ,
fhlA repression by OxyS RNA: kissing complex formation at two sites results in a stable antisense-target RNA complex, J. Mol. Biol, vol.300, issue.5, pp.1101-1112, 2000. ,
Thin junction trees, Advances in Neural Information Processing Systems, pp.569-576, 2002. ,
Development of different peroxidatic activity patterns in pertoneal macrophages in vivo and in vitro, J Reticuloendothel Soc, vol.25, issue.5, pp.513-523, 1979. ,
The protein data bank, Nucleic acids research, vol.28, pp.235-242, 2000. ,
Dynamic programming on graphs with bounded treewidth, International Colloquium on Automata, Languages, and Programming, pp.105-118, 1988. ,
Rna bricks-a database of rna 3d motifs and their interactions, Nucleic Acids Res, vol.42, pp.123-154, 2014. ,
Sequence-based identification of 3D structural modules in RNA with RMDetect, Nat Methods, vol.8, issue.6, pp.513-534, 2011. ,
A statistical sampling algorithm for rna secondary structure prediction, Nucleic acids research, vol.31, pp.7280-7301, 2003. ,
Automated motif extraction and classification in rna tertiary structures, RNA, vol.14, issue.12, pp.2489-97, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00353402
Structure of TAR RNA complexed with a Tat-TAR interaction nanomolar inhibitor that was identified by computational screening, Chem. Biol, vol.9, issue.6, pp.707-712, 2002. ,
De novo discovery of structural motifs in RNA 3D structures through clustering, Nucleic Acids Research, vol.46, issue.9, pp.4783-4793, 2018. ,
Conserved tertiary base pairing ensures proper RNA folding and efficient assembly of the signal recognition particle Alu domain, Nucleic Acids Res, vol.32, issue.16, pp.4915-4924, 2004. ,
Rfam 13.0: shifting to a genome-centric resource for non-coding RNA families, Nucleic Acids Research, vol.46, issue.D1, pp.335-342, 2017. ,
The sarcin-ricin loop of 23S rRNA is essential for assembly of the functional core of the 50S ribosomal subunit, RNA, vol.14, issue.10, pp.1999-2012, 2008. ,
Geometric nomenclature and classification of RNA base pairs, RNA, vol.7, issue.4, pp.499-512, 2001. ,
Geometric nomenclature and classification of rna base pairs, RNA, vol.7, pp.499-512, 2001. ,
Nonredundant 3d structure datasets for rna knowledge extraction and benchmarking, RNA 3D structure analysis and prediction, pp.281-298, 2012. ,
Recurrent structural rna motifs, isostericity matrices and sequence alignments, Nucleic acids research, vol.33, pp.2395-2409, 2005. ,
mabseher: A small but efficient c++ library for computing (customized) tree and hypertree decompositions, Algorithms Mol Biol, vol.6, 2011. ,
RNA secondary structure analysis using RNAstructure, Curr Protoc Bioinformatics Chapter, vol.12, issue.6, 2006. ,
The equilibrium partition function and base pair binding probabilities for rna secondary structure, Biopolymers, vol.29, pp.1105-1119, 1990. ,
Efficient approximations of RNA kinetics landscape using non-redundant sampling, Bioinformatics, vol.33, pp.283-292, 2017. ,
Hierarchy of RNA functional dynamics, Annu. Rev. Biochem, vol.83, pp.441-466, 2014. ,
Structural insights into ligand binding and gene expression control by an adenosylcobalamin riboswitch, Nature structural & molecular biology, vol.19, issue.11, p.1182, 2012. ,
Automated classification of rna 3d motifs and the rna 3d motif atlas, RNA, vol.19, issue.10, pp.1327-1367, 2013. ,
RNA FRABASE 2.0: an advanced web-accessible database with the capacity to search the three-dimensional fragments within RNA structures, BMC Bioinformatics, vol.11, 2010. ,
Towards 3D structure prediction of large rna molecules: an integer programming framework to insert local 3D motifs in RNA secondary structure, Bioinformatics, vol.28, issue.12, pp.207-221, 2012. ,
Mining for recurrent long-range interactions in rna structures reveals embedded hierarchies in network families, Nucleic Acids Research, vol.46, issue.8, pp.3841-3851, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01745345
Non-redundant sampling and statistical estimators for RNA structural properties at the thermodynamic equilibrium (2019), under review ,
Automated, customizable and efficient identification of 3d base pair modules with bayespairing, Nucleic acids research, 2019. ,
A decade of riboswitches, Cell, vol.152, issue.1-2, pp.17-24, 2013. ,
RNA 3D modules in genome-wide predictions of RNA 2D structure, PLoS One, vol.10, issue.10, p.139900, 2015. ,
, RNA Structure Elements Conserved between Mouse and 59 Other Vertebrates, vol.9, 2018.
How RNA folds, J Mol Biol, vol.293, issue.2, pp.271-81, 1999. ,
Nndb: the nearest neighbor parameter database for predicting stability of nucleic acid secondary structure, Nucleic acids research, vol.38, pp.280-282, 2010. ,
Kraken: ultrafast metagenomic sequence classification using exact alignments, Genome biology, vol.15, issue.3, p.46, 2014. ,
Classification of real and pseudo microrna precursors using local structure-sequence features and support vector machine, BMC bioinformatics, vol.6, issue.1, p.310, 2005. ,
Identifying novel sequence variants of RNA 3D motifs, Nucleic Acids Res, vol.43, issue.15, pp.7504-7524, 2015. ,
