Linear Wireless Sensor Networks : Classification and Applications, Journal of Network and Computer Applications, vol.34, issue.5, pp.1671-1682, 2011. ,
Smart Bridges, Smart Tunnels : Transforming Wireless Sensor Networks from Research Prototypes into Robust Engineering Infrastructure, Ad Hoc Networks, vol.8, issue.8, pp.872-888, 2010. ,
Crack Detection in Earth Dam and Levee Passive Seismic Data Using Support Vector Machines, Proc. ICCS 2016, 2016. ,
WARIM : Wireless Sensor Networks Architecture for a Reliable Intersection Monitoring, Proc. IEEE ITSC, 2014. ,
BorderSense : Border Patrol through Advances Wireless Sensor Networks, Ad Hoc Networks, vol.9, issue.3, pp.468-477, 2011. ,
On the problem of unbalanced load distribution in wireless sensor networks, IEEE Global Telecommunications Conference Workshops, pp.74-79, 2004. ,
Characterizing the traffic distribution in linear wireless sensor networks, IEEE Communications Letters, vol.12, issue.8, pp.554-556, 2008. ,
Sensor placement for lifetime maximization in monitoring oil pipelines, Proceedings of the 1st ACM/IEEE International Conference on Cyber-Physical Systems, pp.61-68, 2010. ,
Design guidelines for maximizing lifetime and avoiding energy holes in sensor networks with uniform distribution and uniform reporting, INFOCOM 2006, pp.1-12, 2006. ,
Optimal transmission power in self-sustainable sensor networks for pipeline monitoring, IEEE International Conference on Automation Science and Engineering, pp.591-596, 2007. ,
On the deployment of wireless data back-haul networks, IEEE Transactions on Wireless Communications, vol.6, 2007. ,
A middleware for fast and flexible sensor network deployment, Proceedings of the 32nd international conference on Very large data bases, 2006. ,
From modeling to implementation of virtual sensors in body sensor networks, IEEE Sensors Journal, vol.12, issue.3, pp.583-593, 2012. ,
Sensor Cloud : A Cloud of Virtual Sensors, IEEE Software, vol.31, pp.70-77, 2014. ,
Wireless Communications : Principles and Practise, 1996. ,
A Survey of Network Lifetime Maximization Techniques in Wireless Sensor Networks, IEEE Communications Surveys & Tutorials, vol.19, issue.2, pp.828-854, 2017. ,
Achieving long-term surveillance in vigilnet, ACM Transaction Sensor Networks, vol.5, issue.1, pp.1-39, 2009. ,
Optimal deployment in randomly deployed heterogeneous WSNs : A connected coverage approach, Journal of Network and Computer Applications, vol.46, pp.182-197, 2014. ,
Deploying wireless sensor networks with fault-tolerance for structural health monitoring, IEEE Transactions on Computers, vol.64, issue.2, pp.382-395, 2015. ,
Optimal Planning of WSN Deployments for In SituLunar Surveys, IEEE Transactions on Aerospace and Electronic Systems, vol.53, issue.4, pp.1866-1879, 2017. ,
Optimal WSN deployment models for air pollution monitoring, IEEE Transactions on Wireless Communications, vol.16, issue.5, pp.2723-2735, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01473393
A novel sensor node deployment using low discrepancy sequences for WSN, Wireless Personal Communications, vol.100, issue.2, pp.241-254, 2018. ,
âLifetime improvement in wireless sensor networks using hybrid differential evolution and simulated annealing (DESA)â, Ain Shams Engineering Journal, vol.9, issue.4, pp.655-663, 2018. ,
Nodes Ranking in Wireless Sensor Network with Linear Topology, 2017. ,
WSN Node energy dissipation, Internal Repport, 2006. ,
An overview of routing techniques for road and pipeline monitoring in linear sensor networks, Wireless Networks, 2018. ,
Medium access control with coordinated adaptive sleeping for wireless sensor networks, IEEE/ACM Trans. Netw, vol.12, issue.3, pp.493-506, 2004. ,
On maximizing the lifetime of wireless sensor networks using virtual backbone scheduling, IEEE Trans. Parallel Distrib. Syst, vol.23, issue.8, pp.1528-1535, 2012. ,
Transmission scheduling for optimizing sensor network lifetime : A stochastic shortest path approach, IEEE Trans. Signal Process, vol.55, issue.5, pp.2294-2309, 2007. ,
