Production regimes in four eastern boundary current systems, Deep Sea Res. II, Top. Stud. Oceanogr, vol.50, pp.3199-3221, 2003. ,
Relations environnement et évolution spatio-temporelle des petits poissons pélagiques dans le système d'upwelling de la zone NW Africaine, Lab. Oceanol. Geosci., Littoral Univ, 2016. ,
An improved coastal upwelling index from sea surface temperature using satellite-based approach-The case of the Canary Current upwelling system, Continental Shelf Res, vol.81, pp.38-54, 2014. ,
Coastal upwelling indices, west coast of North America, 1973. ,
On the influence of the Earth's rotation on oceancurrents, Ark. Mat. Astron. Fys, vol.2, pp.1-53, 1905. ,
Seasonal upwelling cycle along the eastern boundary of the north Atlantic, J. Marine Res, vol.34, issue.2, pp.131-141, 1976. ,
Seasonal and temporal study of the northwest African upwelling system, Int. J. Remote Sens, vol.32, issue.7, pp.1843-1859, 2011. ,
Recent changes and trends of the upwelling intensity in the canary current large marine ecosystem, Proc. Oceanographic Biol, pp.321-330, 2015. ,
Mesoscale frontal structures in the canary upwelling system: New front and filament detection algorithms applied to spatial and temporal patterns, Remote Sens. Environ, vol.123, pp.339-346, 2012. ,
Automated computational delimitation of SST upwelling areas using fuzzy clustering, Comput. Geosci, vol.43, pp.207-216, 2012. ,
Identification of upwelling areas on sea surface temperature images using fuzzy clustering, Remote Sens. Environ, vol.112, issue.6, pp.2817-2823, 2008. ,
A simple and efficient approach for coarse segmentation of moroccan coastal upwelling, Proc. 21st Eur. Signal Process. Conf. (EUSIPCO), pp.1-5, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00850445
Upwelling detection in SST images using fuzzy clustering with adaptive cluster merging, Proc. ISIVC, pp.1-5, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01078670
An efficient tool for automatic delimitation of moroccan coastal upwelling using SST images, IEEE Geosci. Remote Sens. Lett, vol.12, issue.4, pp.875-879, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078655
Comparative study of mixing and biological activity of the Benguela and Canary upwelling systems, Geophys. Res. Lett, vol.35, issue.11, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00282578
Surface mixing and biological activity in the North-West African upwelling, Chaos, Interdiscipl. J. Nonlinear Sci, vol.29, issue.1, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01985164
Seasonal and intraseasonal surface chlorophyll-a variability along the Northwest African coast, J. Geophys. Res., Oceans, vol.113, issue.C5, 2008. ,
Seasonal and inter-annual variability of chlorophyll-a concentration in the Mauritanian upwelling: Observation of an anomalous event during 1998-1999, Deep Sea Res. II, Top. Stud. Oceanogr, vol.53, pp.1548-1559, 2006. ,
Temporal and spatial changes in plankton respiration and biomass in the Canary Islands region: The effect of mesoscale variability, J. Marine Syst, vol.54, pp.65-82, 2005. ,
Upwelling features off the coast of North-Western Africa in 2009-2013, Bollettino di Geofisica Teorica ed Applicata, vol.57, issue.1, pp.71-86, 2016. ,
Application of a chlorophyll index derived from satellite data to investigate the variability of phytoplankton in the Benguela ecosystem, Afr. J. Marine Sci, vol.29, issue.2, pp.271-282, 2007. ,
On the size of the Peru upwelling ecosystem, Deep Sea Res. I, Oceanographic Res. Papers, vol.48, issue.11, pp.2521-2528, 2001. ,
An algorithm for oceanic front detection in chlorophyll and SST satellite imagery, J. Marine Syst, vol.78, issue.3, pp.319-326, 2009. ,
On detectability of moroccan coastal upwelling in sea surface temperature satellite images, Proc. Int. Symp. Vis. Comput, pp.386-395, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01078678
A simple tool for automatic extraction of Moroccan coastal upwelling from Sea Surface Temperature images, Proc. 9th ,
URL : https://hal.archives-ouvertes.fr/hal-00973756
, Int. Conf. Intell. Syst., Theories Appl. (SITA), pp.1-4, 2014.
On the global estimates of geostrophic and Ekman surface currents, Limnol. Oceanogr., Fluids Environ, vol.3, issue.1, pp.1-20, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00798745
Adaptive image region-growing, IEEE Trans. Image Process, vol.3, issue.6, pp.868-872, 1994. ,
Fuzzy clustering with volume prototypes and adaptive cluster merging, IEEE Trans. Fuzzy Syst, vol.10, issue.6, pp.705-712, 2002. ,
A robust algorithm for automatic extraction of an unknown number of clusters from noisy data, Pattern Recognit. Lett, vol.17, issue.12, pp.1223-1232, 1996. ,
A clustering performance measure based on fuzzy set decomposition, IEEE Trans. Pattern Anal. Mach. Intell, vol.3, issue.1, pp.66-75, 1981. ,
Particle swarm optimization, Encyclopedia of Machine Learning, pp.760-766, 2011. ,
Swarm Intelligence, 2001. ,
Summer upwelling frequency along the western Cantabrian coast from, J. Mar. Syst, vol.79, issue.2, pp.218-226, 1967. ,
Influence of atmospheric modes on coastal upwelling along the western coast of the iberian peninsula, Climate Res, vol.36, issue.2, pp.169-179, 1985. ,
Annular modes in the extratropical circulation. Part II: Trends, J. Climate, vol.13, issue.5, pp.1018-1036, 2000. ,
The West African coastal upwelling filaments and cross-frontal water exchange conditioned by them, J. Mar. Syst, vol.7, issue.2-4, pp.349-359, 1996. ,
Parameter selection in particle swarm optimization, Proc. Int. Conf. Evol. Program, pp.591-600, 1998. ,
An analysis of particle swarm optimizers, Ph.D. dissertation, Dept. Natural Agricult. Sci., Univ. Pretoria, 2006. ,
