Analyzing the impact of speaker localization errors on speech separation for automatic speech recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate the effect of speaker localization on the performance of speech recognition systems in a multispeaker, multichannel environment. Given the speaker location information, speech separation is performed in three stages. In the first stage, a simple delay-and-sum (DS) beamformer is used to enhance the signal impinging from the speaker location which is then used to estimate a time-frequency mask corresponding to the localized speaker using a neural network. This mask is used to compute the second order statistics and to derive an adaptive beamformer in the third stage. We generated a multichannel, multispeaker, reverberated, noisy dataset inspired from the well studied WSJ0-2mix and study the performance of the proposed pipeline in terms of the word error rate (WER). An average WER of 29.4% was achieved using the ground truth localization information and 42.4% using the localization information estimated via GCC-PHAT. Though higher signal- to-interference ratio (SIR) between the speakers was found to positively impact the speech separation performance, equivalent performances were obtained for mixtures with lower SIR values when the speakers are well separated in space.
conference_101719.pdf (952.16 Ko) Télécharger le fichier
hal-02355669 , version 1 (08-11-2019)
hal-02355669 , version 2 (02-06-2020)
hal-02355669 , version 3 (23-06-2020)
  • HAL Id : hal-02355669 , version 2
Sunit Sivasankaran, Emmanuel Vincent, Dominique Fohr. Analyzing the impact of speaker localization errors on speech separation for automatic speech recognition. 28th European Signal Processing Conference, Jan 2021, Amsterdam, Netherlands. ⟨hal-02355669v2⟩
356 Consultations
408 Téléchargements
