HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
CAD-consistent adaptive refinement using a NURBS-based Discontinuous Galerkin method
Régis Duvigneau 1
1 ACUMES - Analysis and Control of Unsteady Models for Engineering Sciences
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : This study concerns the development of a new method combining high-order CAD-consistent grids and adaptive refinement / coarsening strategies for efficient analysis of compressible flows. The proposed approach allows to use geometrical data from Computer-Aided Design (CAD) without any approximation. Thus, the simulations are based on the exact geometry, even for the coarsest discretizations. Combining this property with a local refinement method allows to start computations using very coarse grids and then rely on dynamic adaption to construct suitable computational domains. The resulting approach facilitates interactions between CAD and Computational Fluid Dynamics (CFD) solvers and focuses the computational effort on the capture of physical phenomena, since geometry is exactly taken into account. The proposed methodology is based on a Discontinuous Galerkin (DG) method for compressible Navier-Stokes equations, modified to use Non-Uniform Rational B-Spline (NURBS) representations. Local refinement and coarsening are introduced using intrinsic properties of NURBS associated to a local error indicator. A verification of the accuracy of the method is achieved and a set of applications are presented, ranging from viscous subsonic to inviscid trans- and supersonic flow problems.
Keywords : OPAL-Meso
Complete list of metadata
Cited literature [48 references]  Display  Hide  Download
https://hal.inria.fr/hal-02355979
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Friday, February 14, 2020 - 3:30:37 PM
Last modification on : Monday, February 14, 2022 - 5:13:34 PM
Long-term archiving on: : Friday, May 15, 2020 - 4:59:17 PM
File
IJNMF_20.pdf
Identifiers
  • HAL Id : hal-02355979, version 2
Citation
Régis Duvigneau. CAD-consistent adaptive refinement using a NURBS-based Discontinuous Galerkin method. International Journal for Numerical Methods in Fluids, Wiley, 2020, 92 (9). ⟨hal-02355979v2⟩
Share
Metrics
Record views
180
Files downloads
192
