A high-order accurate discontinuous finite element method for the numerical solution of the compressible navier-stokes equations, J. Comput. Physics, vol.131, issue.2, pp.267-279, 1997. ,
Higher-order surface treatment for discontinuous Galerkin methods with applications to aerodynamics, Int. J. for Numerical Methods in Fluids, issue.79, pp.323-342, 2015. ,
High-order accurate finite volume scheme on curved boundaries for the two-dimensional steady-state convection-diffusion equation with dirichlet condition, Applied Mathematical Modelling, vol.54, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01399426
NURBS-enhanced finite element method for euler equations, Int. J. for Numerical Methods in Fluids, vol.57, issue.9, 2008. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry, and mesh refinement, Computer Methods in Applied Mechanics and Engineering, issue.194, pp.4135-4195, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01513346
Isogeometric analysis: approximation, stability and error estimates for refined meshes, Mathematical Models and Methods in Applied Sciences, issue.6, pp.1031-1090, 2006. ,
Isogeometric analysis : towards integration of CAD and FEA, 2009. ,
Isogeometric variational multiscale modeling of wall-bounded turbulent flows with weakly-enforced boundary conditions on unstretched meshes, Computer Methods in Applied Mechanics and Engineering, pp.780-790, 0199. ,
Isogeometric divergence-conforming B-Splines for the steady Navier-Stokes equations, Mathematical Models and Methods in Applied Sciences, issue.8, p.23, 2013. ,
Isogeometric analysis of Navier-Stokes flow using locally refinable B-Splines. SAGA -Advances in ShApes, Geometry, and Algebra, vol.10, pp.299-318, 2014. ,
Isogeometric analysis of the navier-stokes equations with taylor-hood b-spline elements, Applied Mathematics and Computation, vol.267, pp.264-281, 2015. ,
Curved mesh generation and mesh refinement using lagrangian solid mechanics, 47th AIAA Aerospace Sciences Meeting, 2009. ,
Construction of tetrahedral meshes of degree two, Int. J. for Numerical Methods in Engineering, vol.90, issue.9, pp.1156-1182, 2012. ,
A method for computing curved meshes via the linear elasticity analogy, application to fluid dynamics problems, Int. J. for Numerical Methods in Fluids, vol.76, pp.246-266, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01045103
The generation of valid curvilinear meshes, Notes on Numerical Fluid Mechanics and Multidisciplinary Design, vol.128, pp.15-39, 2015. ,
Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.229-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01517950
Parametrization of computational domain in isogeometric analysis: methods and comparison, Computer Methods in Applied Mechanics and Engineering, vol.200, pp.23-24, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00530758
Analysis-suitable volume parameterization of multi-block computational domain in isogeometric analysis, Computer Aided Design, vol.45, issue.2, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00685002
Optimizing domain parameterization in isogeometric analysis based on Powell-Sabin splines, Journal of Computational and Applied Mathematics, vol.289, pp.68-86, 2015. ,
Isogeometric analysis using LR B-Splines, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.471-514, 2014. ,
Swept volume parameterization for isogeometric analysis, 13th IMA International Conference on Mathematics of Surfaces, pp.19-44, 2009. ,
Isogeometric triangular bernstein-bézier discretizations: automatic mesh generation and geometrically exact finite-element analysis, Computer Methods in Applied Mechanics and Engineering, issue.304, pp.378-407, 2016. ,
Isogeometric unstructured tetrahedral and mixed-element bernstein-bézier discretizations, Computer Methods in Applied Mechanics and Engineering, issue.319, pp.83-123, 2017. ,
isogeometric analysis on triangulations, Computer Aided Design, issue.46, pp.45-57, 2014. ,
Continuity and convergence in rational triangular bézier spline based isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, issue.297, pp.292-324, 2015. ,
Isogeometric analysis with bézier tetrahedra, Computer Methods in Applied Mechanics and Engineering, issue.316, pp.782-816, 2017. ,
The finite element method in engineering science, 1971. ,
Foundations of the blended isogeometric discontinuous Galerkin (BIDG) method, Computer Methods in Applied Mechanics and Engineering, vol.305, pp.658-681, 2016. ,
Isogeometric analysis for compressible flows using a Discontinuous Galerkin method, Computer Methods in Applied Mechanics and Engineering, vol.333, pp.443-461, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01589344
Curves and Surfaces for Computer-Aided Geometric Design, 1989. ,
The NURBS book, 1995. ,
A Practical Guide to Splines, 1978. ,
Locally refined splines. Non-Standard Numerical Methods for PDEs, 2010. ,
Constructing analysis-suitable parameterization of computational domain from cad boundary by variational harmonic method, J. Comput, vol.252, 2013. ,
URL : https://hal.archives-ouvertes.fr/inria-00585663
Bézier extraction and adaptive refinement of truncated hierarchical NURBS, Computer Methods in Applied Mechanics and Engineering, vol.305, pp.316-339, 2016. ,
Multi-level Bézier extraction for hierarchical local refinement of isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.328, pp.147-174, 2018. ,
Studies of refinement and continuity in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, pp.4160-4183, 0196. ,
, Nodal Discontinuous Galerkin Methods, 2008.
High-Order Methods for Computational Physics, chap. Discontinuous Galerkin Methods for Convection-Dominated Problems, 1999. ,
On the choice of wavespeeds for the hllc Riemann solver, SIAM J. Sci. Comput. November, vol.18, issue.6, pp.1553-1570, 1997. ,
Riemann Solvers and Numerical Methods for Fluid Dynamics, 1997. ,
The local discontinuous galerkin method for time-dependent convection-diffusion systems, SIAM Journal of Num. An, vol.35, issue.6, pp.2440-2463, 1998. ,
A guide to the implementation of boundary conditions in compact high-order methods for compressible aerodynamics, 7th AIAA Theoretical Fluid Mechanics Conference, 2014. ,
Sub-cell shock capturing for discontinuous galerkin methods, 2006. ,
Shock capturing with PDE-based artificial viscosity for DGFEM: Part i. formulation, J. Comput. Physics, vol.229, issue.5, pp.1810-1827, 2010. ,
Anisotropic mesh refinement for discontinuous galerkin methods in two-dimensional aerodynamic flow simulations, Int. J. for Numerical Methods in Fluids, vol.56, issue.11, pp.2111-2138, 2008. ,
An efficient adaptive mesh refinement (AMR) algorithm for the discontinuous galerkin method: Applications for the computation of compressible two-phase flows, J. Comput. Physics, vol.363, pp.399-427, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02011549
Anisotropic and dynamic mesh adaptation for discontinuous galerkin methods applied to reactive transport, Computer Methods in Applied Mechanics and Engineering, vol.195, pp.3382-3405, 2006. ,
