Efficient Direct Slicing Of Dilated And Eroded 3d Models For Additive Manufacturing: Technical Report
In the context of additive manufacturing we present a novel technique for direct slicing of a dilated or eroded volume, where the input volume boundary is a triangle mesh. Rather than computing a 3D model of the boundary of the dilated or eroded volume, our technique directly produces its slices. This leads to a computationally and memory efficient algorithm, which is embarrassingly parallel. Contours can be extracted under an arbitrary chord error, non-uniform dilation or erosion are also possible. Finally, the scheme is simple and robust to implement.
