, New method for building a high-order discrete CAD model ? Most elements are aligned with iso-parametric curves ? accurate description of the surface geometry
, ? Also meshing for numerical simulations: efficiency, non-degenerate and piecewise constant derivatives, parallelism ? Work in progress: ? Complete distance evaluation ? Parallelization of high-order meshing
