Deciding Feasibility of a Booking in the European Gas Market on a Cycle is in P
We show that the feasibility of a booking in the European entry-exit gas market can be decided in polynomial time on passive single-cycle networks, i.e., on networks without controllable elements. The feasibility of a booking can be characterized by solving polynomially many nonlinear potential-based flow models for computing so-called potential-difference maximizing load flow scenarios. We thus analyze the structure of these models and exploit both the cyclic graph structure as well as specific properties of potential-based flows. This enables us to solve the decision variant of the nonlinear potential-difference maximization by reducing it to a system of polynomials of constant dimension that is independent of the cycle's size. This system of fixed dimension can be handled with tools from real algebraic geometry to derive a polynomial-time algorithm. The characterization in terms of potential-difference maximizing load flow scenarios then leads to a polynomial-time algorithm for deciding the feasibility of a booking. Our theoretical results extend the existing knowledge about the complexity of deciding the feasibility of bookings from trees to single-cycle networks.
