New interface
Journal articles
Deciding Feasibility of a Booking in the European Gas Market on a Cycle is in P for the Case of Passive Networks
Martine Labbé 1 Fränk Plein 2, 1 Martin Schmidt 3 Johannes Thürauf 4
1 INOCS - Integrated Optimization with Complex Structure
Inria Lille - Nord Europe, ULB - Université libre de Bruxelles, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : We show that the feasibility of a booking in the European entry-exit gas market can be decided in polynomial time on single-cycle networks that are passive, i.e., do not contain controllable elements. The feasibility of a booking can be characterized by solving polynomially many nonlinear potential-based flow models for computing so-called potential-difference maximizing load flow scenarios. We thus analyze the structure of these models and exploit both the cyclic graph structure as well as specific properties of potential-based flows. This enables us to solve the decision variant of the nonlinear potential-difference maximization by reducing it to a system of polynomials of constant dimension that is independent of the cycle's size. This system of fixed dimension can be handled with tools from real algebraic geometry to derive a polynomial-time algorithm. The characterization in terms of potential-difference maximizing load flow scenarios then leads to a polynomial-time algorithm for deciding the feasibility of a booking. Our theoretical results extend the existing knowledge about the complexity of deciding the feasibility of bookings from trees to single-cycle networks.
Complete list of metadata
Cited literature [37 references]  Display  Hide  Download
https://hal.inria.fr/hal-02360972
Contributor : Fränk Plein Connect in order to contact the contributor
Submitted on : Friday, October 16, 2020 - 5:01:44 PM
Last modification on : Tuesday, December 6, 2022 - 12:42:13 PM
File
preprint-version-2020-10-16.pd...
Identifiers
Collections
Citation
Martine Labbé, Fränk Plein, Martin Schmidt, Johannes Thürauf. Deciding Feasibility of a Booking in the European Gas Market on a Cycle is in P for the Case of Passive Networks. Networks, 2021, ⟨10.1002/net.22003⟩. ⟨hal-02360972v3⟩
Share
Metrics
Record views
62
Files downloads
138
