, Network Flows: Theory, Algorithms, and Applications, 1993.
Decomposable Robust Two-Stage Optimization: An Application to Gas Network Operations under Uncertainty, vol.74, pp.40-61, 2019. ,
Deciding Robust Feasibility and Infeasibility Using a Set Containment Approach: An Application to Stationary Passive Gas Network Operations, In: SIAM Journal on Optimization, vol.28, pp.2489-2517, 2018. ,
The Gas Transmission Problem When the Merchant and the Transport Functions Are Disconnected, 2007. ,
, Algorithms in Real Algebraic Geometry, vol.10, 2007.
Robust optimization, 2009. ,
Adjustable robust solutions of uncertain linear programs, Mathematical Programming, vol.99, pp.351-376, 2004. ,
Solving the Pipe Network Analysis Problem Using Optimization Techniques, Management Science, vol.24, pp.747-760, 1978. ,
The Gas Transmission Problem Solved by an Extension of the Simplex Algorithm, Management Science, vol.46, pp.1454-1465, 2000. ,
Mathematical Optimization for Challenging Network Planning Problems in Unbundled Liberalized Gas Markets, In: Energy Systems, vol.5, pp.449-473, 2013. ,
The Reservation-Allocation Network Flow Problem, 2014. ,
Towards Globally Optimal Solutions for MINLPs by Discretization Techniques with Applications in Gas Network Optimization, 2011. ,
A New Algorithm for MINLP Applied to Gas Transport Energy Cost Minimization, pp.321-353, 2013. ,
Solving Highly Detailed Gas Transport MINLPs: Block Separability and Penalty Alternating Direction Methods, In: INFORMS Journal on Computing, vol.30, pp.309-323, 2018. ,
On the quantification of nomination feasibility in stationary gas networks with random load, In: Mathematical Methods of Operations Research, vol.84, pp.427-457, 2016. ,
Algorithmic Results for Potential-Based Flows: Easy and Hard Cases, vol.73, pp.306-324, 2019. ,
Geometric Algorithms and Combinatorial Optimization, Algorithms and Combinatorics, vol.2, 1988. ,
Computing maximal entry and exit capacities of transportation networks, 2016. ,
The New Entry-Exit Model in the EU and Its Consequences for Gas Supply Companies ,
, , pp.477-491, 2009.
Gas Network Optimization by MINLP, 2017. ,
Evaluating Gas Network Capacities, 2015. ,
Bookings in the European Gas Market: Characterisation of Feasibility and Computational Complexity Results, In: Optimization and Engineering, 2019. ,
Optimierung Technischer Kapazitäten in Gasnetzen, Optimierung in der Energiewirtschaft. VDI-Berichte 2157, pp.105-114, 2011. ,
Mixed Integer Models for the Stationary Case of Gas Network Optimization, Mathematical Programming, vol.105, issue.2, pp.563-582, 2006. ,
Étude de réseaux de transport et de distribution de fluide, In: RAIRO -Operations Research, vol.11, issue.2, pp.243-248, 1977. ,
, concerning common rules for the internal market in natural gas and repealing Directive 98/30/EC (OJ L, vol.176, pp.57-78, 2003.
, Directive 2009/73/EC of the European Parliament and of the Council concerning common rules for the internal market in natural gas and repealing Directive, vol.55, pp.36-54, 2003.
, concerning common rules for the internal market in natural gas, OJ L, vol.204, pp.1-12, 1998.
Optimization Problems in Natural Gas Transportation Systems: A State-of-the-Art Review, In: Applied Energy, vol.147, pp.536-555 ,
A Reduction Technique for Natural Gas Transmission Network Optimization Problems, In: Annals of Operations Research, vol.117, issue.1, pp.217-234, 2002. ,
Robust Optimal Discrete Arc Sizing for Tree-Shaped Potential Networks, Computational Optimization and Applications, vol.73, pp.791-819, 2019. ,
Structural Properties of Feasible Bookings in the European Entry-Exit Gas Market System, p.4, 2019. ,
High Detail Stationary Optimization Models for Gas Networks, In: Optimization and Engineering, vol.16, issue.1, pp.131-164, 2015. ,
Validation of Nominations in Gas Networks and Properties of Technical Capacities, 2014. ,
In analogy to Case 1, the modification decreases f 4 , which contradicts the optimality of the original solution, 08.031. d), vol.277, p.1050, 2018. ,
, Fürther Str. 250, 90429 Nürnberg, p.91058
