Linearly implicit methods for nonlinear parabolic equations, Mathematics of Computation, vol.73, issue.246, pp.613-635, 2004. ,
Fully implicit, linearly implicit and implicit-explicit backward difference formulae for quasi-linear parabolic equations, Numerische Mathematik, vol.131, pp.713-735, 2015. ,
A semi-implicit mid-point rule for stiff systems of ordinary differential equations, Numerische Mathematik, vol.41, pp.373-398, 1983. ,
Nonnegative Matrices in the Mathematical Sciences, Classics in Applied Mathematics. Society for Industrial Mathematics, 1987. ,
A relaxation scheme for the nonlinear Schrödinger equation, SIAM J. Numer. Anal, vol.42, issue.3, pp.934-952, 2004. ,
Energy-preserving methods for nonlinear Schrödinger equations, IMA Journal of Numerical Analysis, 2020. ,
High order exponential integrators for nonlinear Schrödinger equations with application to rotating Bose-Einstein condensates, SIAM J. Numer. Anal, vol.55, issue.3, pp.1387-1411, 2017. ,
Diagonally-implicit multi-stage integration methods, Applied Numerical Mathematics, vol.11, issue.5, pp.347-363, 1993. ,
, Selected Topics in Numerical Methods, vol.31, pp.105-112, 1996.
Runge-Kutta methods: some historical notes, Special Issue Celebrating the Centenary of Runge-Kutta Methods, vol.22, pp.113-151, 1996. ,
Linearly implicit Runge-Kutta methods for advection-reaction-diffusion equations, Applied Numerical Mathematics, vol.37, issue.4, pp.535-549, 2001. ,
Multiple Scalar Auxiliary Variable (MSAV) approach and its application to the phase-field vesicle membrane model, SIAM Journal on Scientific Computing, vol.40, issue.6, pp.3982-4006, 2018. ,
A practical method for numerical evaluation of solutions of partial differential equations of the heat-conduction type, Proc. Cambridge Philos. Soc, vol.43, pp.50-67, 1947. ,
A special stability problem for linear multistep methods, BIT Numerical Mathematics, vol.3, pp.27-43, 1963. ,
Finite-difference solutions of a nonlinear Schrödinger equation, J. Comput. Phys, vol.44, issue.2, pp.277-288, 1981. ,
Exponential Runge-Kutta methods for the Schrödinger equation, Applied Numerical Mathematics, vol.59, issue.8, pp.1839-1857, 2009. ,
The concept of B-convergence, SIAM Journal on Numerical Analysis, vol.18, issue.5, pp.753-780, 1981. ,
, Geometric Numerical Integration: Structure-Preserving Algorithms for Ordinary Differential Equations, 2002.
, Solving Ordinary Differential Equations I: Nonstiff Problems, vol.8, 1993.
, Solving Ordinary Differential Equations II. Stiff and Differential-Algebraic Problems, vol.14, 1996.
On nonexistence of global solutions of some semilinear parabolic differential equations, Proc. Japan Acad, vol.49, pp.503-505, 1973. ,
Exponential Runge-Kutta methods for parabolic problems, Tenth Seminar on Numerical Solution of Differential and Differential-Algebraic Equations, vol.53, pp.323-339, 2005. ,
Exponential integrators, Acta Numerica, vol.19, pp.209-286, 2010. ,
A study of Rosenbrock-type methods of high order, Numerische Mathematik, vol.38, 1981. ,
Linearly implicit full discretization of surface evolution, Numerische Mathematik, vol.140, pp.121-152, 2018. ,
Beitrag zur naherungsweisen integration totaler differentialgleichungen, Z. Math. Phys, vol.46, pp.435-453, 1901. ,
On splitting methods for Schrödinger-Poisson and cubic nonlinear Schrödinger equations, Math. Comp, vol.77, issue.264, pp.2141-2153, 2008. ,
Linearly implicit time discretization of non-linear parabolic equations, IMA Journal of Numerical Analysis, vol.15, issue.4, pp.555-583, 1995. ,
Families of high-order composition methods, Numerical Algorithms, vol.31, issue.1, pp.233-246, 2002. ,
Some general implicit processes for the numerical solution of differential equations, The Computer Journal, vol.5, issue.4, pp.329-330, 1963. ,
Ueber die numerische auflösung von differentialgleichungen, Mathematische Annalen, vol.46, pp.167-178, 1895. ,
Iterative Methods for Sparse Linear Systems, Second edn, Society for Industrial and Applied Mathematics, 2003. ,
Convergence and error analysis for the Scalar Auxiliary Variable (SAV) schemes to gradient flows, SIAM Journal on Numerical Analysis, vol.56, issue.5, pp.2895-2912, 2018. ,
B-convergence results for linearly implicit one step methods, BIT Numerical Mathematics, vol.27, pp.264-281, 1987. ,
A study of B-convergence of linearly implicit Runge-Kutta methods, Computing, vol.40, pp.241-253, 1988. ,
Fractal decomposition of exponential operators with applications to many-body theories and Monte Carlo simulations, Phys. Lett. A, vol.146, issue.6, pp.319-323, 1990. ,
A class of linearly-implicit Runge-Kutta methods for multibody systems, Special Issue Celebrating the Centenary of Runge-Kutta Methods, vol.22, pp.381-398, 1996. ,
Construction of higher order symplectic integrators, Physics Letters A, vol.150, issue.5, pp.262-268, 1990. ,
