Dutch modal complement ellipsis, Empirical Issues in Syntax and Semantics, vol.7, pp.7-33, 2008. ,
The Syntactic Licensing of Ellipsis. Amsterdam: J. Benjamins. Barbiers, Sjef. 1995. The syntax of interpretation PhD thesis, 2010. ,
Restructuring and Functional Structure, Structures and Beyond, pp.132-191, 2004. ,
What Sluicing Can Do, What it Can't, and In Which Language: On the Cross-Linguistic Syntax of Ellipsis, Diagnosing Syntax, pp.486-502, 2013. ,
VP-Ellipsis in European and Brazilian Portuguese -a comparative analysis, Journal of Portuguese Linguistics, vol.1, pp.177-195, 2002. ,
L'Ellipse modale en français : arguments pour une ellipse du TP, Actes du CMLF'08, pp.2453-2465, 2008. ,
Modal Ellipsis in French, Spanish and Italian: evidence for a TP-deletion analysis, Romance Linguistics 2008: Interactions in Romance. Amsterdam: Benjamins, pp.157-170, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00881807
On null complement anaphora in Spanish and Italian, Probus, vol.13, pp.193-221, 2001. ,
Pseudogaping and Ellipsis, 2013. ,
VP-ellipsis and the Czech auxiliary být, Journal XLinguae, vol.5, pp.2-16, 2012. ,
VP-Elipsa, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01682527
, Nový encyklopedický slovník ?e?tiny, Prague: Lidové noviny
Deep and Surface Anaphora, Linguistic Inquiry, vol.7, pp.391-428, 1976. ,
Verb Phrase Ellipsis: Form, Meaning and Processing, 1993. ,
Identifying the timing of clitic placement in Serbo-Croatian: an argument from ellipsis. Talk presented at FDSL 12, vol.5, 2017. ,
Semi-lexical Heads in Czech Modal Structures, 2008. ,
When Can You Save A Structure By Destroying It, Proceedings of NELS 31. GLSA, pp.301-320, 2001. ,
Ellipsis: Functional Heads, Licensing and Identification, 1995. ,
Transparency phenomena in Czech syntax, 2000. ,
The Syntax of Silence: Sluicing, Islands, and the Theory of Ellipsis, 2001. ,
An Asymmetry in Voice mismatches in VP-ellipsis and Pseudogapping, Linguistic Inquiry, vol.39, pp.169-179, 2008. ,
Variable Island repair under Ellipsis, Topics in Ellipsis, pp.132-153, 2008. ,
Voice and ellipsis, Linguistic Inquiry, vol.44, pp.77-108, 2013. ,
A Restructuring Rule in Italian Syntax, Recent Transformational Studies in European Languages, pp.113-158, 1978. ,
Restructuring, Head Movement, and Locality, Linguistic Inquiry, vol.28, pp.423-460, 1991. ,
Agreement and head Movement: Clitics, Incroporation, and defective Goals, Linguistic Inquiry Monograph, 2010. ,
Auxiliaries as Main Verbs, Studies in Philosophical Linguistics, pp.77-102, 1969. ,
Guess who?, Papers from the 5th meeting of CLS, pp.252-286, 1969. ,
Théorie syntaxique et syntaxe du français, Editions du Seuil. Sag, Ivan. 1976. Deletion and LF, 1972. ,
Wh-movement out of the site of VP ellipsis, Syntax at Santa Cruz. Linguistic Department: UC, pp.1-20, 2001. ,
Phrasal Movement and X° Morphology: Word order parallels in Czech and English nominal and verbal projections, The extended verbal projection in Czech: Three variants of the verb být, 1995. ,
, Formal Description of Slavic Languages: The Fifth Conference, pp.555-569, 2003.
Modal Verbs must be Raising Verbs, Proceedings of WCCFL 18, pp.599-612, 1999. ,
Infinitives: Restructuring and Clause Structure, 2001. ,
