Turbulent route to two-dimensional soft crystals
We investigate the effects of a two-dimensional, incompressible, turbulent flow on mono-disperse soft granular particles and show the emergence of a crystalline phase due to the interplay of Stokesian drag (measured through the Stokes number) and short-range inter-particle interactions. We quantify this phase through the bond order parameter and local density fluctuations and find a sharp transition between the crystalline and non-crystalline phase as a function of the Stokes number. Furthermore, the nature of preferential concentration, as characterised by the radial distribution function and the correlation dimension $D_2$, is significantly different from that of particle-laden flows in the absence of repulsive potentials.
