Regulatory Considerations in the 5G Era: The 5GCity Neutral Host Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The need for densification in 5G networks will necessitate the installation of large amounts of small cells in dense urban environments in order to meet future demands for capacity. The Neutral Host model has been proposed as a potential solution to this problem. This paper discusses the general regulatory considerations of 5G networks and specific considerations that relate to the Neutral Host model as this has been examined as part of the H2020 Project 5GCity.
484534_1_En_10_Chapter.pdf (145.15 Ko) Télécharger le fichier
hal-02363835 , version 1 (14-11-2019)
Paternité
Ioannis Neokosmidis, Theodoros Rokkas, Dimitrios Xydias, Maria Rita Spada. Regulatory Considerations in the 5G Era: The 5GCity Neutral Host Case. 15th IFIP International Conference on Artificial Intelligence Applications and Innovations (AIAI), May 2019, Hersonissos, Greece. pp.111-120, ⟨10.1007/978-3-030-19909-8_10⟩. ⟨hal-02363835⟩
58 Consultations
73 Téléchargements
