Institutions for SQL Database Schemas and Datasets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Databases and the query language SQL play a major role in modern applications. In this paper we present an institution-based formalisation of relational databases that uses structures close to those used in SQL. This is the essential difference to other category-theoretical formalisations of databases, which often depart quite far from the SQL standard. We also study SQL queries, using institutional monads, and prove cocompleteness and amalgamation results for the institution.
486157_1_En_4_Chapter.pdf (539.8 Ko) Télécharger le fichier
hal-02364575 , version 1 (15-11-2019)
Paternité
Martin Glauer, Till Mossakowski. Institutions for SQL Database Schemas and Datasets. 24th International Workshop on Algebraic Development Techniques (WADT), Jul 2018, Egham, United Kingdom. pp.67-86, ⟨10.1007/978-3-030-23220-7_4⟩. ⟨hal-02364575⟩
137 Consultations
35 Téléchargements
