Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : Event Structures where the causality may change dynamically have been introduced recently. In this kind of Event Structures the changes in the set of the causes of an event are triggered by modifiers that may add or remove dependencies, thus making the happening of an event contextual. Still the focus is always on the dependencies of the event. In this paper we promote the idea that the context determined by the modifiers plays a major rôle, and the context itself determines not only the causes but also what causality should be. Modifiers are then used to understand when an event (or a set of events) can be added to a configuration, together with a set of events modeling dependencies, which will play a less important rôle. We show that most of the notions of Event Structure presented in literature can be translated into this new kind of Event Structure, preserving the main notion, namely the one of configuration.
https://hal.inria.fr/hal-02365495 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, November 15, 2019 - 2:12:48 PM Last modification on : Friday, November 15, 2019 - 2:30:38 PM Long-term archiving on: : Sunday, February 16, 2020 - 5:28:26 PM
G. Michele Pinna. Representing Dependencies in Event Structures. 21th International Conference on Coordination Languages and Models (COORDINATION), Jun 2019, Kongens Lyngby, Denmark. pp.3-18, ⟨10.1007/978-3-030-22397-7_1⟩. ⟨hal-02365495⟩
