Lessons Learned from an Organizational Information Security Awareness Campaign - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Juan-Marc Scrimgeour
  • Fonction : Auteur
  • PersonId : 1058400
Jacques Ophoff
  • Fonction : Auteur
  • PersonId : 1053934
Educating end-users to improve information security awareness plays an important part in securing organizational environments. While best practice standards provide a set of minimum information security awareness controls that should be implemented, little guidance is given on how to implement these controls to ensure the effectiveness of training. This research defined and evaluated a method for implementing an information security awareness campaign (ISAC) within an organization. The method is based on prior research and standards, while assisting the subject in improving their ISAC through the creation of artefacts and measurement techniques. A design science research approach was used with several research cycles to design the method. The method was implemented within an organization and evaluated based on the impact, effectiveness and results of each step, as well as the feedback from participants (two questionnaires were completed by 47 and 36 employees respectively). The research found both positive and negative results. Certain steps within the method proved time consuming and confusing to some participants. Although improvements can be made, the method was found to be adequate as it achieved the required objective within the organization and provided the organization with a risk-based method and visual representation to measure awareness on specific information security awareness topics. The results of the study not only provided value to the organization but provides a validated method for implementing an ISAC which could be applied in other contexts.
485999_1_En_10_Chapter.pdf (305.65 Ko) Télécharger le fichier
hal-02365728 , version 1 (15-11-2019)
Paternité
Juan-Marc Scrimgeour, Jacques Ophoff. Lessons Learned from an Organizational Information Security Awareness Campaign. 12th IFIP World Conference on Information Security Education (WISE), Jun 2019, Lisbon, Portugal. pp.129-142, ⟨10.1007/978-3-030-23451-5_10⟩. ⟨hal-02365728⟩
70 Consultations
114 Téléchargements
