Point pair features based object detection and pose estimation revisited, 3D Vision (3DV), 2015. ,
Analysis of quadric-surface-based solid models, IEEE Computer Graphics and Applications, vol.8, issue.1, pp.28-42, 1988. ,
Quadric reconstruction from dual-space geometry, International Conference on Computer Vision, 1998. ,
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.11, pp.1115-1138, 1991. ,
Type-constrained direct fitting of quadric surfaces, Computer-Aided Design and Applications, 2014. ,
Robust and repeatable fitting of implicit polynomial curves to point data sets and to intensity images, 2001. ,
The 3l algorithm for fitting implicit polynomial curves and surfaces to data, IEEE Transactions on Pattern Analysis and Machine Intelligence, 2000. ,
Typeconstrained robust fitting of quadrics with application to the 3d morphological characterization of saddle-shaped articular surfaces, International Conference on Computer Vision, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-02164443
User-guided inverse 3d modeling, 2013. ,
Real-time 3d scene description using spheres, cones and cylinders, 2016. ,
A minimalist approach to type-agnostic detection of quadrics in point clouds, Computer Vision and Pattern Recognition (CVPR), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01855977
A survey of methods for recovering quadrics in triangle meshes, ACM Computing Surveys (CSUR), 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00100762
3-d point cloud normal estimation based on fitting algebraic spheres, Image Processing (ICIP), 2016 IEEE International Conference on, pp.2589-2592, 2016. ,
Quadric surface extraction by variational shape approximation, International Conference on Geometric Modeling and Processing, pp.73-86, 2006. ,
Robust segmentation of raw point clouds into consistent surfaces, Science China Technological Sciences, 2016. ,
Efficient intersection of three quadrics and applications in computer vision, Proceedings of the IEEE Conference on Computer Vision and Pattern Recognition, 2016. ,
Grasp planning using quadric surface approximation for parallel grippers, International Conference on Robotics and Biomimetics (ROBIO), 2013. ,
Localizing grasp affordances in 3-d points clouds using taubin quadric fitting, 2013. ,
Probabilistic structure from motion with objects (psfmo), The IEEE International Conference on Computer Vision (ICCV), 2017. ,
Think locally, fit globally: Robust and fast 3d shape matching via adaptive algebraic fitting, Neurocomputing, 2017. ,
The 3d hough transform for plane detection in point clouds: A review and a new accumulator design, 3D Research, vol.2, 2011. ,
Globfit: Consistently fitting primitives by discovering global relations, ACM Transactions on Graphics, 2011. ,
Efficient ransac for point-cloud shape detection, Computer graphics forum, 2007. ,
Extraction of reliable primitives from unorganized point clouds, 3D Research, 2015. ,
Rapter: rebuilding man-made scenes with regular arrangements of planes, ACM Trans. Graph, vol.34, issue.4, pp.103-104, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01498225
Planar shape detection and regularization in tandem, Computer Graphics Forum, vol.35, issue.1, pp.203-215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01168394
Planar shape detection at structural scales, IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01741650
6d dbscan-based segmentation of building point clouds for planar object classification, Automation in Construction, vol.88, pp.44-58, 2018. ,
Pipe-run extraction and reconstruction from point clouds, ECCV, 2014. ,
Local hough transform for 3d primitive detection, 3D Vision (3DV), International Conference on, 2015. ,
Robust fitting of ellipsoids by separating interior and exterior points during optimization, Journal of Mathematical Imaging and Vision, 2016. ,
Object detection in point clouds using conformal geometric algebra, Advances in Applied Clifford Algebras, pp.1-16, 2017. ,
Fitting quadrics with a bayesian prior, Computational Visual Media, 2016. ,
Further improving geometric fitting, International Conference on 3-D Digital Imaging and Modeling, 2005. ,
Variational mesh segmentation via quadric surface fitting, Computer-Aided Design, 2012. ,
Geometric data abstraction using b-splines for range image segmentation, Robotics and Automation, International Conference on, 2013. ,
Representing quadric surfaces using nurbs surfaces, Journal of Computer Science and Technology, vol.12, 1997. ,
Representing spheres and ellipsoids using periodic nurbs surfaces with fewer control vertices, Pacific Graphics. Pacific Conference, 1998. ,
Grasping unknown objects in clutter by superquadric representation, 2017. ,
Segmentation through variable-order surface fitting, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.10, issue.2, pp.167-192, 1988. ,
Extraction of quadrics from noisy point-clouds using a sensor noise model, Robotics and Automation, International Conference on, 2010. ,
Robust extraction of planar and quadric surfaces from range images, International Conference on Pattern Recognition (ICPR), 2004. ,
Ransac for (quasi-) degenerate data (qdegsac)," in Computer Vision and Pattern Recognition, IEEE Computer Society Conference on, vol.1, pp.453-460, 2006. ,
Scene segmentation driven by deep learning and surface fitting, ECCV Workshops, 2016. ,
A review on deep learning techniques applied to semantic segmentation, 2017. ,
Ppfnet: Global context aware local features for robust 3d point matching, Computer Vision and Pattern Recognition (CVPR), 2018. ,
, Ppf-foldnet: Unsupervised learning of rotation invariant 3d local descriptors, The European Conference on Computer Vision (ECCV), 2018.
3d-prnn: Generating shape primitives with recurrent neural networks, Proc. ICCV, vol.2, 2017. ,
PCPNet: Learning local shape properties from raw point clouds, Computer Graphics Forum, vol.37, issue.2, pp.75-85, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01741744
MathWorld -A Wolfram Web Resource, 2017. ,
Classifying quadrics using exact arithmetic, Geometric Tools, LLC, Tech. Rep, 2008. ,
Classification of quadrics, 2009. ,
Algebraic curves that work better, Computer Vision and Pattern Recognition (CVPR), 1999. ,
Dynamic sampling and rendering of algebraic point set surfaces, Computer Graphics Forum, vol.27, pp.653-662, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00354995
Remarks on some nonparametric estimates of a density function, The Annals of Mathematical Statistics, 1956. ,
Random sample consensus: A paradigm for model fitting with applications to image analysis and automated cartography, Commun. ACM, 1981. ,
In defense of the eight-point algorithm, IEEE Transac, 1997. ,
A point sampling algorithm for 3d matching of irregular geometries, 2017 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.6871-6878, 2017. ,
Surface reconstruction from unorganized points, vol.26, 1992. ,
Difference of normals as a multi-scale operator in unorganized point clouds, 3DIMPVT, 2012, International Conference on, 2012. ,
X-tag: A fiducial tag for flexible and accurate bundle adjustment, IEEE Conference on 3D Vision, 2016. ,
, A large dataset of object scans, 2016.
Introducing mvtec itodd -a dataset for 3d object recognition in industry, The IEEE International Conference on Computer Vision (ICCV), 2017. ,
Robust registration of 2d and 3d point sets, Image and Vision Computing, vol.21, issue.13, pp.1145-1153, 2003. ,
Combining scale-space and similarity-based aspect graphs for fast 3d object recognition, IEEE transactions, 2012. ,
An efficient ransac for 3d object recognition in noisy and occluded scenes, 2010. ,
