Using Explainability for Constrained Matrix Factorization, Proceedings of the Eleventh ACM Conference on Recommender Systems, pp.79-83, 2017. ,
Biclustering neighborhood-based collaborative filtering method for top-n recommender systems, Knowledge and Information Systems, vol.44, issue.2, pp.475-491, 2015. ,
, Netflix Recommendations: Beyond the 5 stars, 2012.
A generalized maximum entropy approach to Bregman co-clustering and matrix approximation, KDD-2004 -Proceedings of the Tenth ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, pp.509-514, 2004. ,
Precision-oriented Evaluation of Recommender Systems: An Algorithmic Comparison, Proceedings of the Fifth ACM Conference on Recommender Systems, pp.333-336, 2011. ,
Enhancing privacy and preserving accuracy of a distributed collaborative filtering, Proceedings of the 2007 ACM Conference on Recommender Systems, RecSys, pp.9-16, 2007. ,
Recommender systems survey. Knowledge-Based Systems, vol.46, pp.109-132, 2013. ,
Collaborative Filtering Under a Sybil Attack: Similarity Metrics do Matter! In, 48th Annual IEEE/IFIP International Conference on Dependable Systems and Networks, DSN 2018, pp.466-477, 2018. ,
Hybrid Recommender Systems: Survey and Experiments, User Model. User-Adapt. Interact, vol.12, issue.4, pp.331-370, 2002. ,
Collaborative filtering with privacy via factor analysis, SIGIR 2002: Proceedings of the 25th Annual International ACM SIGIR Conference on Research and Development in Information Retrieval, pp.238-245, 2002. ,
Applying Biclustering to Perform Collaborative Filtering, Seventh International Conference on Intelligent Systems Design and Applications, pp.421-426, 2007. ,
Biclustering of Expression Data, Proceedings of the Eighth International Conference on Intelligent Systems for Molecular Biology, pp.93-103, 2000. ,
Deep Neural Networks for YouTube Recommendations, Proceedings of the 10th ACM Conference on Recommender Systems, pp.191-198, 2016. ,
Performance of Recommender Algorithms on Topn Recommendation Tasks, Proceedings of the Fourth ACM Conference on Recommender Systems, pp.39-46, 2010. ,
Co-clustering documents and words using bipartite spectral graph partitioning, Proceedings of the seventh ACM SIGKDD international conference on Knowledge discovery and data mining, pp.269-274, 2001. ,
Beyond Accuracy: Evaluating Recommender Systems by Coverage and Serendipity, Proceedings of the Fourth ACM Conference on Recommender Systems, pp.257-260, 2010. ,
A Scalable Collaborative Filtering Framework Based on Co-Clustering, Proceedings of the 5th IEEE International Conference on Data Mining (ICDM 2005), pp.625-628, 2005. ,
Eigentaste: A Constant Time Collaborative Filtering Algorithm, Information Retrieval, vol.4, pp.133-151, 2001. ,
The Netflix Recommender System: Algorithms, Business Value, and Innovation, ACM Trans. Management Inf. Syst, vol.6, issue.4, 2016. ,
A survey of accuracy evaluation metrics of recommendation tasks, Journal of Machine Learning Research, vol.10, pp.2935-2962, 2009. ,
An efficient Java implementation of the immediate successors calculation, Concept Lattices and their Applications, pp.81-92, 2013. ,
Learning the K in K-Means, Advances in Neural Information Processing Systems, vol.17, 2004. ,
The MovieLens Datasets: History and Context, ACM Trans. Interact. Intell. Syst, vol.5, issue.4, 2015. ,
Evaluating Collaborative Filtering Recommender Systems, ACM Trans. Inf. Syst, vol.22, issue.1, pp.5-53, 2004. ,
A Survey and Empirical Analysis of Beyond-Accuracy Objectives in Recommender Systems, ACM Trans. Interact. Intell. Syst, vol.7, issue.1, 2016. ,
A New Measure of Rank Correlation, Biometrika, vol.30, 1938. ,
Matrix Factorization Techniques for Recommender Systems, IEEE Computer, vol.42, issue.8, pp.30-37, 2009. ,
QUBIC: a qualitative biclustering algorithm for analyses of gene expression data, Nucleic acids research, vol.37, issue.15, pp.101-101, 2009. ,
Industry Report: Amazon.com Recommendations: Itemto-Item Collaborative Filtering, IEEE Distributed Systems Online, vol.4, issue.1, 2003. ,
Predicting Online Performance of News Recommender Systems Through Richer Evaluation Metrics, Proceedings of the 9th ACM Conference on Recommender Systems, pp.179-186, 2015. ,
Differentially Private Recommender Systems: Building Privacy into the Netflix Prize Contenders, Proceedings of the 15th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, pp.627-636, 2009. ,
Extracting Conserved Gene Expression Motifs from Gene Expression Data, Proceedings of the 8th Pacific Symposium on Biocomputing, pp.77-88, 2003. ,
Robust de-anonymization of large datasets (how to break anonymity of the Netflix prize dataset), 2008. ,
A biclustering method for gene expression module discovery using a closed itemset enumeration algorithm, IPSJ Digital Courier, vol.3, pp.183-192, 2007. ,
Location-based recommendation system using bayesian user's preference model in mobile devices, International conference on ubiquitous intelligence and computing, pp.1130-1139, 2007. ,
Content-Based Recommendation Systems, The Adaptive Web, Methods and Strategies of Web Personalization, vol.4321, pp.325-341, 2007. ,
X-means: Extending K-means with Efficient Estimation of the Number of Clusters, Proceedings of the Seventeenth International Conference on Machine Learning, pp.727-734, 2000. ,
A systematic comparison and evaluation of biclustering methods for gene expression data, Bioinformatics, vol.22, issue.9, pp.1122-1129, 2006. ,
Comparative Recommender System Evaluation: Benchmarking Recommendation Frameworks, Proceedings of the 8th ACM Conference on Recommender Systems, pp.129-136, 2014. ,
Item-based collaborative filtering recommendation algorithms, Proceedings of the 10th international conference on World Wide Web, pp.285-295, 2001. ,
Methods and Metrics for Cold-start Recommendations, Proceedings of the 25th Annual International ACM SIGIR Conference on Research and Development in Information Retrieval, pp.253-260, 2002. ,
Eclipse Attacks on Overlay Networks: Threats and Defenses, INFOCOM 2006. 25th IEEE International Conference on Computer Communications, Joint Conference of the IEEE Computer and Communications Societies, pp.23-29, 2006. ,
Impact of biclustering on the performance of Biclustering based Collaborative Filtering, Expert Syst. Appl, vol.113, pp.443-456, 2018. ,
Nearest-biclusters collaborative filtering based on constant and coherent values, Inf. Retr, vol.11, issue.1, pp.51-75, 2008. ,
HIFCF: An effective hybrid model between picture fuzzy clustering and intuitionistic fuzzy recommender systems for medical diagnosis, Expert Systems with Applications, vol.42, issue.7, pp.3682-3701, 2015. ,
On the Robustness and Discriminative Power of Information Retrieval Metrics for top-N Recommendation, Proceedings of the 12th ACM Conference on Recommender Systems, pp.260-268, 2018. ,
Collaborative Deep Learning for Recommender Systems, Proceedings of the 21th ACM SIGKDD International Conference on Knowledge Discovery and Data Mining, pp.1235-1244, 2015. ,
Large-Scale Parallel Collaborative Filtering for the Netflix Prize, Proc. 4th Int'l Conf. Algorithmic Aspects in Information and Management, vol.5034, pp.337-348, 2008. ,
Improving recommendation lists through topic diversification, 2005. ,
