Fiber composition of the human corpus callosum, Brain research, vol.598, issue.1, pp.143-153, 1992. ,
Orientationally invariant indices of axon diameter and density from diffusion MRI, NeuroImage, vol.52, issue.4, pp.1374-1389, 2010. ,
Measurement of fiber orientation distributions using high angular resolution diffusion imaging, Magnetic Resonance in Medicine, vol.54, issue.5, pp.1194-1206, 2005. ,
Axcaliber: a method for measuring axon diameter distribution from diffusion mri. Magnetic Resonance, Medicine, vol.59, issue.6, pp.1347-1354, 2008. ,
MR diffusion tensor spectroscopy and imaging, Biophys J, vol.66, issue.1, p.259, 1994. ,
URL : https://hal.archives-ouvertes.fr/hal-00349721
Calculating geometric properties of threedimensional objects from the spherical harmonic representation, Pattern Recognition, vol.40, issue.2, pp.756-770, 2007. ,
Design of multishell sampling schemes with uniform coverage in diffusion mri, Magnetic resonance in medicine, vol.69, issue.6, pp.1534-1540, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00821688
On facilitating the use of hardi in population studies by creating rotation-invariant markers, Medical image analysis, vol.20, issue.1, pp.87-96, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01090154
Double diffusion encoding prevents degeneracy in parameter estimation of biophysical models in diffusion mri, 2018. ,
Regularized, fast, and robust analytical q-ball imaging, Magnetic Resonance in Medicine, vol.58, issue.3, pp.497-510, 2007. ,
Computer simulations in solid-state nmr. iii. powder averaging. Concepts in Magnetic Resonance Part A, An Educational Journal, vol.18, issue.1, pp.24-55, 2003. ,
Apolarity and canonical forms for homogeneous polynomials, European Journal of Combinatorics, vol.14, issue.3, pp.157-181, 1993. ,
Whole brain segmentation: automated labeling of neuroanatomical structures in the human brain, Neuron, vol.33, pp.341-355, 2002. ,
Characterization of anisotropy in high angular resolution diffusion-weighted mri, Magnetic Resonance in Medicine, vol.47, issue.6, pp.1083-1099, 2002. ,
Biomarkers for hardi: 2nd amp; 4th order tensor invariants, 2012 9th IEEE International Symposium on Biomedical Imaging (ISBI), pp.26-29, 2012. ,
Generalized invariants of a 4th order tensor: Building blocks for new biomarkers in dmri, Proceedings of the Computation Diffusion MRI Workshop at the MICCAI Conference, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00789763
Some properties of the coupling coefficients of real spherical harmonics and their relation to gaunt coefficients, proceedings of the Second Electronic Computational Chemistry Conference, vol.368, pp.31-37, 1996. ,
Degeneracy in model parameter estimation for multi-compartmental diffusion in neuronal tissue, NMR in Biomedicine, vol.29, issue.1, pp.33-47, 2016. ,
Neurite density from magnetic resonance diffusion measurements at ultrahigh field: Comparison with light microscopy and electron microscopy, NeuroImage, vol.49, issue.1, pp.205-216, 2010. ,
Modeling dendrite density from magnetic resonance diffusion measurements, NeuroImage, vol.34, issue.4, pp.1473-1486, 2007. ,
Multi-compartment microscopic diffusion imaging, NeuroImage, vol.139, pp.346-359, 2016. ,
Quantitative mapping of the per-axon diffusion coefficients in brain white matter, Magnetic Resonance in Medicine, vol.75, issue.4, pp.1752-1763, 2016. ,
A theory of phase-sensitive rotation invariance with spherical harmonic and moment-based representations, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.105-112, 2010. ,
The complexity of the annihilating polynomial, 24th Annual IEEE Conference on Computational Complexity, pp.184-193, 2009. ,
A novel set of rotationally and translationally invariant features for images based on the non-commutative bispectrum, 2007. ,
On information and sufficiency, Ann. Math. Statist, vol.22, issue.1, pp.79-86, 1951. ,
Neurite density imaging versus imaging of microscopic anisotropy in diffusion mri: A model comparison using spherical tensor encoding, NeuroImage, vol.147, pp.517-531, 2017. ,
Dependence on b-value of the direction-averaged diffusion-weighted imaging signal in brain, Magnetic resonance imaging, vol.36, pp.121-127, 2017. ,
Quantifying brain microstructure with diffusion mri: Theory and parameter estimation, 2016. ,
Rotationallyinvariant mapping of scalar and orientational metrics of neuronal microstructure with diffusion mri, NeuroImage, vol.174, pp.518-538, 2018. ,
Mean apparent propagator (map) mri: a novel diffusion imaging method for mapping tissue microstructure, NeuroImage, vol.78, pp.16-32, 2013. ,
Generalized diffusion tensor imaging and analytical relationships between diffusion tensor imaging and high angular resolution diffusion imaging, Magnetic Resonance in Medicine, vol.50, issue.5, pp.955-965, 2003. ,
Generalized scalar measures for diffusion mri using trace, variance, and entropy, Magnetic Resonance in Medicine, vol.53, issue.4, pp.866-876, 2005. ,
Complete set of invariants of a 4th order tensor: The 12 tasks of hardi from ternary quartics, Medical Image Computing and Computer-Assisted Intervention -MICCAI, pp.233-240, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01092492
Disentangling micro from mesostructure by diffusion mri: A bayesian approach, NeuroImage, 2016. ,
Non-gaussian diffusion imaging: a brief practical review, proceedings of the International School on Magnetic Resonance and Brain Function, vol.29, issue.10, pp.1410-1416, 2011. ,
Visualization and Processing of Tensors and Higher Order Descriptors for Multi-Valued Data, pp.129-161, 2014. ,
Information Processing in Medical Imaging, pp.705-717, 2013. ,
Fast probabilistic algorithms for verification of polynomial identities, J. ACM, vol.27, issue.4, pp.701-717, 1980. ,
Advances in diffusion MRI acquisition and processing in the human connectome project, Neuroimage, vol.80, pp.125-143, 2013. ,
Robust determination of the fibre orientation distribution in diffusion mri: non-negativity constrained super-resolved spherical deconvolution, NeuroImage, vol.35, issue.4, pp.1459-1472, 2007. ,
Direct estimation of the fiber orientation density function from diffusion-weighted mri data using spherical deconvolution, NeuroImage, vol.23, issue.3, pp.1176-1185, 2004. ,
NODDI: Practical in vivo neurite orientation dispersion and density imaging of the human brain, Neuroimage, vol.61, issue.4, pp.1000-1016, 2012. ,
Probabilistic algorithms for sparse polynomials, pp.216-226, 1979. ,
Noddi-sh: a computational efficient noddi extension for fodf estimation in diffusion mri, 2017. ,
A generalized smt-based framework for diffusion mri microstructural model estimation, Computational Diffusion MRI, pp.51-63, 2018. ,
A Closed-Form Solution of Rotation Invariant Spherical Harmonic Features in Diffusion MRI, MICCAI -Computational Diffusion MRI Workshop, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01912148
