Low-quality dimension reduction and high-dimensional approximate nearest neighbor, Proc. Annual Symp. on Computational Geometry, pp.436-450, 2015. ,
Near-optimal hashing algorithms for approximate nearest neighbor in high dimensions, Commun. ACM, vol.51, issue.1, pp.117-122, 2008. ,
An optimal algorithm for approximate nearest neighbors in fixed dimension, J.ACM, vol.45, pp.891-923, 1998. ,
The inverted multi-index, Computer Vision and Pattern Recognition, pp.3069-3076, 2012. ,
Random projection trees and low dimensional manifolds, Proc. ACM STOC, pp.537-546, 2008. ,
Report for k-d GeRaF parameter auto tunning, 2015. ,
Product quantization for nearest neighbor search, IEEE Trans. Pattern Analysis & Machine Intell, vol.33, issue.1, pp.117-128, 2011. ,
Locally optimized product quantization for approximate nearest neighbor search, Comp. Vision & Pattern Recogn, 2014. ,
The Art of Computer Programming, vol.2, 1998. ,
Fast approximate nearest neighbors with automatic algorithm configuration, Proc. VISAPP: Intern. Conf. Computer Vision Theory & Appl, pp.331-340, 2009. ,
Scalable nearest neighbour algorithms for high dimensional data. Pattern Analysis and Machine Intelligence, 2014. ,
Towards good practice in large-scale learning for image classification, Computer Vision and Pattern Recognition, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00690014
Object retrieval with large vocabularies and fast spatial matching, Comp Vision & Pattern Recogn, 2007. ,
Optimised kd-trees for fast image descriptor matching, Proc. IEEE Computer Vision & Pattern Recognition, 2008. ,
Randomly-oriented kd-trees adapt to intrinsic dimension, Proc. Foundations Software Techn. & Theor. Comp. Science, pp.48-57, 2012. ,
Hashing for similarity search: A survey, 2014. ,
Spectral hashing, Proc. NIPS 21, pp.1753-1760, 2008. ,
