Matrix algebra, 2005. ,
, Graph fibrations, graph isomorphism, and PageRank. RAIRO-Theoretical Informatics and Applications, vol.40, pp.227-253, 2006.
, Geometric deep learning: going beyond euclidean data, 2016.
, Spectral networks and locally connected networks on graphs, 2013.
Fast, exact and multi-scale inference for semantic image segmentation with deep Gaussian CRFs, ECCV, vol.4, p.5, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01410872
Cluster kernels for semisupervised learning, NIPS, issue.5, pp.601-608, 2003. ,
Total recall: Automatic query expansion with a generative feature model for object retrieval, ICCV, 2001. ,
Spectral graph theory, American Mathematical Soc, vol.92, issue.2, 1997. ,
Introduction to algorithms, vol.5, p.6, 2009. ,
Convolutional neural networks on graphs with fast localized spectral filtering, NIPS, pp.3837-3845, 2016. ,
Diffusion processes for retrieval revisited, CVPR, p.5, 2013. ,
On the Nyström method for approximating a gram matrix for improved kernel-based learning, Journal of Machine Learning Research, vol.6, issue.2, pp.2153-2175, 2005. ,
Fast and exact top-k search for random walk with restart, Proceedings of the VLDB Endowment, vol.5, pp.442-453, 2012. ,
Deep image retrieval: Learning global representations for image search, ECCV, issue.1, 2016. ,
End-to-end learning of deep visual representations for image retrieval, 2008. ,
Random walks for image segmentation, IEEE Trans. PAMI, vol.28, issue.11, pp.1768-1783, 2006. ,
Iterative solution of large sparse systems of equations, 1994. ,
Finding structure with randomness: Probabilistic algorithms for constructing approximate matrix decompositions, SIAM Review, vol.53, issue.2, pp.217-288, 2004. ,
Wavelets on graphs via spectral graph theory. Applied and Computational Harmonic Analysis, vol.30, pp.129-150, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00541855
Deep residual learning for image recognition, CVPR, 2016. ,
, Deep convolutional networks on graph-structured data, 2015.
An input-output approach to clique identification, Sociometry, issue.5, 1965. ,
Memory vectors for similarity search in high-dimensional spaces, IEEE Trans. Big Data, vol.4, issue.1, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01481220
Efficient diffusion on region manifolds: Recovering small objects with compact cnn representations, CVPR, vol.7, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01505470
Product quantization for nearest neighbor search, IEEE Trans. PAMI, vol.33, issue.1, pp.117-128, 2011. ,
Random walk with restart on large graphs using block elimination, ACM Transactions on Database Systems, vol.41, issue.2, p.12, 2016. ,
Learning semantic similarity, NIPS, 2002. ,
Beyond 'caveman communities': Hubs and spokes for graph compression and mining, Proceedings of the IEEE International Conference on Data Mining, vol.5, pp.300-309, 2011. ,
A new status index derived from sociometric analysis, Psychometrika, vol.18, issue.1, pp.39-43, 1953. ,
Generative image segmentation using random walks with restart, ECCV, pp.264-275, 2008. ,
, Diffusion kernels. Kernel Methods in Computational Biology, pp.171-192, 2004.
Diffusion kernels on graphs and other discrete structures, ICML, 2002. ,
Nonlinear dimensionality reduction, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01517215
, Geometric deep learning on graphs and manifolds using mixture model cnns, 2016.
Generalized max-pooling, CVPR, 2014. ,
Diffusion maps, spectral clustering and eigenfunctions of fokker-planck operators, NIPS, issue.5, 2005. ,
Numerical optimization, 2006. ,
Discrete-Time Signal Processing: Pearson New International Edition, p.4, 2010. ,
The PageRank citation ranking: bringing order to the web, vol.1, p.5, 1999. ,
Automatic multimedia cross-modal correlation discovery, International Conference on Knowledge Discovery and Data Mining, vol.4, p.5, 2004. ,
Object retrieval with large vocabularies and fast spatial matching, CVPR, 2007. ,
Lost in quantization: Improving particular object retrieval in large scale image databases, CVPR, 2008. ,
Unifying local and non-local signal processing with graph cnns, 2017. ,
Hello neighbor: Accurate object retrieval with k-reciprocal nearest neighbors, CVPR, 2011. ,
CNN image retrieval learns from bow: Unsupervised fine-tuning with hard examples. ECCV, 2008. ,
Visual instance retrieval with deep convolutional networks, ITE Transactions on Media Technology and Applications, vol.4, issue.8, pp.251-258, 2016. ,
A randomized algorithm for principal component analysis, SIAM Journal on Matrix Analysis and Applications, vol.31, issue.3, pp.1100-1124, 2009. ,
Multiscale anisotropic texture unsupervised clustering for photographic paper, IEEE International Workshop on Information Forensics and Security, pp.1-6, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01511889
, Gaussian Markov random fields: theory and applications, 2005.
Discrete signal processing on graphs, IEEE Transactions on Signal Processing, vol.61, issue.7, p.5, 2013. ,
The net of reciprocal influence. a problem in treating sociometric data, Canadian Journal of Experimental Psychology, vol.3, issue.5, p.234, 1949. ,
Kernel methods for pattern analysis, 2004. ,
Spatially-constrained similarity measure for large-scale object retrieval, IEEE Trans. PAMI, vol.36, issue.6, pp.1229-1241, 2014. ,
The emerging field of signal processing on graphs: Extending high-dimensional data analysis to networks and other irregular domains, IEEE Signal Processing Magazine, vol.30, issue.3, p.5, 2013. ,
Chebyshev polynomial approximation for distributed signal processing, International Conference on Distributed Computing in Sensor Systems and Workshops, pp.1-8, 2011. ,
Very deep convolutional networks for large-scale image recognition. ICLR, 2014. ,
Kernels and regularization on graphs, Learning Theory and Kernel Machines, pp.144-158, 2003. ,
The connection between regularization operators and support vector kernels, Neural Networks, vol.11, issue.4, pp.637-649, 1998. ,
Learning Gaussian conditional random fields for low-level vision, CVPR, pp.1-8, 2007. ,
Particular object retrieval with integral max-pooling of cnn activations. ICLR, vol.1, p.6, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01842218
Fast random walk with restart and its applications, Proceedings of the IEEE International Conference on Data Mining, vol.4, p.5, 2006. ,
Numerical linear algebra, SIAM, issue.2, 1997. ,
Graph wavelets for multiscale community mining, IEEE Transactions on Signal Processing, vol.62, issue.20, pp.5227-5239, 2014. ,
, Spectral ranking, vol.4, p.5, 2009.
Graph kernels, Journal of Machine Learning Research, vol.11, issue.5, pp.1201-1242, 2010. ,
Graphical models, exponential families, and variational inference. Foundations and Trends in Machine Learning, vol.649, 2008. ,
Instre: a new benchmark for instance-level object retrieval and recognition, ACM Transactions on Multimedia Computing, Communications, and Applications (TOMM), vol.11, p.6, 2015. ,
Randomized algorithms for low-rank matrix factorizations, Sharp performance bounds, 2013. ,
Learning with local and global consistency, NIPS, vol.4, p.5, 2003. ,
Ranking on data manifolds, NIPS, vol.1, p.5, 2003. ,
Semi-supervised learning using Gaussian fields and harmonic functions, ICML, 2003. ,
Graph kernels by spectral transforms. Semi-Supervised Learning, pp.277-291, 2006. ,
Semi-supervised learning: From Gaussian fields to Gaussian processes, 2003. ,
