Case-based Reasoning: Foundational Issues, Methodological Variations, and System Approaches, AI Communications, vol.7, issue.1, pp.39-59, 1994. ,
Towards analogy-based decision -A proposal, Proc. 12th Conf. on Flexible Query Answering Systems (FQAS'17), vol.10333, pp.28-35, 2017. ,
Analogical classification: A rule-based view, Proc. of the International Conference on Information Processing and Management of Uncertainty in Knowledge-Based Systems, pp.485-495, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01394666
Trying to understand how analogical classifiers work, Proc. of the International Conference on Scalable Uncertainty Management, pp.582-589, 2012. ,
Analogy-preserving functions: a way to extend Boolean samples, Proc. of the 26th Int. Joint Conf. on Artificial Intelligence (IJCAI'17), pp.1575-1581, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01668230
Learning adaptation knowledge to improve case-based reasoning, Artificial Intelligence, vol.170, pp.1175-1192, 2006. ,
Case base mining for adaptation knowledge acquisition, Proc. of the 20th Int. Joint Conf. on Artificial Intelligence (IJCAI'07), pp.750-755, 2007. ,
Multiple-valued extensions of analogical proportions, Fuzzy Sets and Systems, vol.292, pp.193-202, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01475021
Improving Adaptation Knowledge Discovery by Exploiting Negative Cases: First Experiment in a Boolean Setting, Proc. of ICCBR 2018 -26th International Conference on Case-Based Reasoning, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01905077
Learning adaptation rules from a case-base, Advances in Case-Based Reasoning -Proc. of the Third Eur. Workshop, EWCBR'96. LNAI 1168, pp.179-192, 1996. ,
Learning and applying adaptation rules for categorical features: An ensemble approach, AI Communications, vol.30, issue.3-4, pp.193-205, 2017. ,
Using case-base data to learn adaptation knowledge for design, Proc. of the 17th Int. Joint Conf. on Artificial Intelligence (IJCAI'01), pp.1011-1016, 2001. ,
Case-Based Reasoning, 1993. ,
Language, Production, Cognition and the Lexicon. Text, Speech and Language Technology 48, pp.151-173, 2014. ,
Making the Best of Cases by Approximation, Interpolation and Extrapolation, ICCBR 2018 -26th International Conference on Case-Based Reasoning, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01905058
A discussion of analogical-proportion based inference, Doctoral Consortium, and Competitions co-located with the 25th Int. Conf. on Case-Based Reasoning (ICCBR'17), vol.2028, pp.73-82, 2017. ,
Case-based reasoning, a textbook, 2013. ,
Inside Case-Based Reasoning, 1989. ,
Remembering to forget, Proc. of the 14th Int. Joint Conf. on Artificial Intelligence (IJCAI'95), 1995. ,
Analogical learning and formal proportions: Definitions and methodological issues, 2005. ,
Remembering to add: competence-preserving case-addition policies for case base maintenance, Proc. of the 16th Int. Joint Conf. on Artificial Intelligence (IJCAI'99, pp.234-241, 1999. ,
