A Non-Overlapping Schwarz Domain Decomposition Method with High-Order Finite Elements for Flow Acoustics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2020
A non-overlapping domain decomposition method is proposed to solve large-scale finite element models for the propagation of sound with a background mean flow. An additive Schwarz algorithm is used to split the computational domain into a collection of sub-domains, and an iterative solution procedure is formulated in terms of unknowns defined on the interfaces between sub-domains. This approach allows to solve large-scale problems in parallel with only a fraction of the memory requirements compared to the standard approach which is to use a direct solver for the complete problem. While domain decomposition techniques have been used extensively for Helmholtz problems, this is the first application to aero-acoustics. The optimized Schwarz formulation is extended to the linearized potential theory for sound waves propagating in a potential base flow. A high-order finite element method is used to solve the governing equations in each sub-domain, and well-designed interface conditions based on local approximations of the Dirichlet-to-Neumann map are used to accelerate the convergence of the iterative procedure. The method is assessed on an academic test case and its benefit demonstrated on a realistic turbofan engine intake configuration.
A_Non-Overlapping_Schwarz_Domain_Decomposition_Method.pdf (10.3 Mo) Télécharger le fichier
hal-02371050 , version 1 (19-11-2019)
Alice Lieu, Philippe Marchner, Gwenael Gabard, Hadrien Beriot, Xavier Antoine, et al.. A Non-Overlapping Schwarz Domain Decomposition Method with High-Order Finite Elements for Flow Acoustics. Computer Methods in Applied Mechanics and Engineering, 2020, ⟨10.1016/j.cma.2020.113223⟩. ⟨hal-02371050⟩
279 Consultations
89 Téléchargements
