Nonlinear control systems, 1995. ,
Sliding Modes in Control and Optimization, 1992. ,
Sliding mode in control engineering, 2002. ,
Quasi-continuous high-order sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, pp.1812-1816, 2005. ,
Homogeneous high order sliding mode design: a Lyapunov approach, Automatica, vol.80, pp.232-238, 2017. ,
Finite-time and fixedtime stabilization: Implicit Lyapunov function method, Automatica, vol.51, issue.1, pp.332-340, 2015. ,
Nonlinear systems, 2002. ,
Homogeneity approach to high-order sliding mode, Automatica, vol.41, pp.823-830, 2005. ,
A Lyapunov approach to second-order sliding mode controllers and observers, Proceedings of the IEEE Conference on Decision and Control, pp.2856-2861, 2008. ,
High precision control of robots manipulators via finite-time p-pi control, 51st IEEE Conference on Decision and Control, 2012. ,
Control integral discontinuo para sistemas mecánicos, Asociación de México de Control Automático (AMCA), pp.11-16, 2013. ,
Discontinuous integral control for mechanical systems, 14th International Workshop on Variable Structure Systems (VSS), pp.142-147, 2016. ,
Continuous terminal sliding-mode controller, Automatica, vol.69, pp.308-314, 2016. ,
Discontinuous integral control for systems in controller form, Asociación de México de Control Automático (AMCA), 2017. ,
New Perspectives and Applications of Modern Control Theory;in Honor of Alexander S. Poznyak, vol.8, 2018. ,
Higher order supertwisting for perturbed chains of integrators, IEEE Transactions on Automatic Control, vol.62, issue.7, pp.3588-3593, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02307513
On homogeneity and its application in sliding mode control, Journal of the Franklin Institute, vol.351, issue.4, pp.1816-1901, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942326
Lyapunov functions and stability in control theory, vol.2, 2005. ,
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, issue.6, pp.467-473, 1992. ,
Smooth lyapunov functions for homogeneous differential inclusions, Proceedings of the 41st SICE Annual Conference, vol.3, p.19741979, 2002. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
On an extension of homogeneity notion for differential inclusions, European Control Conference, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00801818
Differential equations with discontinuous righthand side, 1988. ,
Stabilization of the reaction wheel pendulum via a third order discontinuous integral sliding mode algorithm, Proceedings of IEEE International Workshop on Variable Structure Systems, pp.132-137, 2018. ,
