, Partial Stability and Control, 1998.
On the stability of nonholonomic mechanical systems with respect to partial variables, Appl.Math. Mech, vol.16, issue.3, pp.237-245, 1995. ,
A discussion on the Hölder and robust finite-time partial stabilizability of Brockett's integrator, ESAIM: Control, Optimisation and Calculus of Variations, vol.18, pp.360-382, 2012. ,
Continuous and discontinuous homogeneous feedbacks finite-time partially stabilizing controllable multichained systems, SIAM Journal on Control and Optimization, vol.52, issue.1, pp.520-544, 2014. ,
Forward completeness, unboundedness observability, and their Lyapynov characterizations, Systems & Control Letters, vol.38, pp.209-217, 1999. ,
, Input to State Stability and Allied System Properties, Automation and Remote Control, vol.72, pp.1579-1614, 2011.
On Input-to-Output Stability for Systems not Uniformly Bounded, Proc. NOLCOS, 2001. ,
Lyapunov Characterizations of Input to Output Stability, SIAM J. Control Optim, issue.39, pp.226-249, 2000. ,
A Notion of Input to Output Stability, Proc. Eur. Control Conf., Brussels, 1997. ,
Notions of Input to Output Stability, Syst. Control Lett, issue.38, pp.235-248, 1999. ,
, On Notions of Output Finite-Time Stability, 17th European Control Conference (ECC19), 2019.
Finite-time stability of continuous autonomous systems, SIAM Journal of Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal of Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
, Finite time stability and stabilization of a class of continuous systems, Journal of Mathematical Analysis and Application, vol.323, issue.2, pp.1430-1443, 2006.
On systems of ordinary differential equations with generalized homogeneous right-hand sides, Izvestia vuzov. Mathematica, vol.1, pp.80-88, 1958. ,
, Lyapunov Functions and Stability in Control Theory, 2005.
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, pp.467-473, 1992. ,
Finite-time partial stability and stabilization, and optimal feedback control, Journal of the Franklin Institute, vol.352, pp.2329-2357, 2015. ,
Stable adaptive systems, 1989. ,
, Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, vol.51, pp.332-340, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01098099
