Discretization of the PN model for 2D transport of particles with a Trefftz Discontinuous Galerkin method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
A discretization of the PN model for 2D transport of particles is presented, together with the derivation of new high order convergence estimates and new numerical results for the P1 and P3 models. The discretization method is based on recent advances about the construction of a Trefftz Discontinuous Galerkin (TDG) method for Friedrichs systems coming from linear transport with relaxation are presented in a comprehensive setting. More numerical results in 2 dimensions illustrate the theoretical properties.
TDGPN_6 HAL.pdf (2.15 Mo) Télécharger le fichier
hal-02372279 , version 1 (20-11-2019)
hal-02372279 , version 2 (18-09-2020)
  • HAL Id : hal-02372279 , version 2
Christophe Buet, Bruno Després, Guillaume Morel. Discretization of the PN model for 2D transport of particles with a Trefftz Discontinuous Galerkin method. 2020. ⟨hal-02372279v2⟩
192 Consultations
190 Téléchargements
