Reports
Joint NN-Supported Multichannel Reduction of Acoustic Echo, Reverberation and Noise: Supporting Document
Guillaume Carbajal 1 Romain Serizel 1 Emmanuel Vincent 1 Eric Humbert 2
1 MULTISPEECH - Speech Modeling for Facilitating Oral-Based Communication
Inria Nancy - Grand Est, LORIA - NLPKD - Department of Natural Language Processing & Knowledge Discovery
Abstract : This technical report is the supporting document of our proposed approach basedon a neural network for joint multichannel reduction of echo, reverberation and noise [1]. First, werecall the model of the proposed approach. Secondly, we express the vectorized computation of echocancellation and dereverberation. Thirdly, we detail the complete derivation of the update rules.Fourthly we describe the computation of the ground truth targets for the neural network usedin our approach. Fifthly we detail the variant of the proposed approach where echo cancellationand dereverberation are performed in parallel. Sixthly we describe the variant of the proposedapproach where only echo cancellation is performed. Then we specify the recording and simulationparameters of the dataset, we detail the computation of the estimated early near-end componentsand we recall the baselines. Finally we give the results after each filtering step and providesestimated spectrogram examples by all the approaches.
Complete list of metadatas
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02372431
Contributor : Guillaume Carbajal <>
Submitted on : Friday, July 10, 2020 - 2:33:30 PM
Last modification on : Sunday, August 2, 2020 - 4:53:52 AM
File
RR-9303.pdf
Identifiers
  • HAL Id : hal-02372431, version 4
Citation
Guillaume Carbajal, Romain Serizel, Emmanuel Vincent, Eric Humbert. Joint NN-Supported Multichannel Reduction of Acoustic Echo, Reverberation and Noise: Supporting Document. [Research Report] RR-9303, INRIA Nancy; Invoxia SAS. 2019. ⟨hal-02372431v4⟩
Share
Metrics
Record views
18
Files downloads
98
