Conjugate gradient algorithm for optimization under unitary matrix constraint, Signal Processing, vol.89, pp.1704-1714, 2009. ,
Using Asymmetry in the Spectral Clustering of Trajectories, 2011. ,
Accurate Computation of the Log-Sum-Exp and Softmax Functions, 2019. ,
A unifying theorem for spectral embedding and clustering, 2003. ,
The Geometry of Algorithms with Orthogonality Constraints, SIAM Journal on Matrix Analysis and Applications, vol.20, issue.2, pp.303-353, 1998. ,
A tutorial on spectral clustering, Statistics and Computing, vol.17, pp.395-416, 2007. ,
