Audio Source Separation and Speech Enhancement, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01881431
Acoustic Echo and Noise Control: a Practical Approach, 2004. ,
Correlation-based and model-based blind single-channel late-reverberation suppression in noisy time-varying acoustical environments, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1746-1765, 2010. ,
Joint dereverberation and noise reduction based on acoustic multi-channel equalization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.4, pp.680-693, 2016. ,
Multi-microphone speech dereverberation and noise reduction using relative early transfer functions, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.23, issue.2, pp.240-251, 2015. ,
Joint multimicrophone speech dereverberation and noise reduction using integrated sidelobe cancellation and linear prediction, Proc. IWAENC, pp.221-225, 2018. ,
Blind separation and dereverberation of speech mixtures by joint optimization, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.1, pp.69-84, 2011. ,
Joint separation and dereverberation of reverberant mixtures with determined multichannel nonnegative matrix factorization, Proc. ICASSP, pp.31-35, 2018. ,
Combined noise and echo reduction in hands-free systems: a survey, IEEE Transactions on Speech and Audio Processing, vol.9, issue.8, pp.808-820, 2001. ,
A psychoacoustic approach to combined acoustic echo cancellation and noise reduction, IEEE Transactions on Speech and Audio Processing, vol.10, issue.5, pp.245-256, 2002. ,
Joint optimization of LCMV beamforming and acoustic echo cancellation for automatic speech recognition, Proc. ICASSP, 2005. ,
Joint noise reduction and acoustic echo cancellation using the transfer-function generalized sidelobe canceller, Speech Communication, vol.49, issue.7-8, pp.623-635, 2007. ,
Frequency domain acoustic echo reduction based on Kalman smoother with time-varying noise covariance matrix, Proc. ICASSP, pp.5909-5913, 2014. ,
Joint acoustic echo and noise cancellation using spectral domain Kalman filtering in double talk scenario, Proc. IWAENC, pp.326-330, 2018. ,
ICA-based efficient blind dereverberation and echo cancellation method for barge-in-able robot audition, Proc. ICASSP, pp.3677-3680, 2009. ,
Speech enhancement combined with dereverberation and acoustic echo reduction for time varying systems, Proc. SSP, pp.357-360, 2012. ,
Joint dereverberation and residual echo suppression of speech signals in noisy environments, IEEE Transactions on Audio, Speech, and Language Processing, vol.16, issue.8, pp.1433-1451, 2008. ,
Simultaneous optimization of acoustic echo reduction, speech dereverberation, and noise reduction against mutual interference, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.11, pp.1612-1623, 2014. ,
Speech dereverberation and denoising using complex ratio masks, Proc. ICASSP, pp.5590-5594, 2017. ,
A two-stage algorithm for noisy and reverberant speech enhancement, Proc. ICASSP, pp.5580-5584, 2017. ,
Integrated acoustic echo and background noise suppression based on stacked deep neural networks, Applied Acoustics, vol.133, pp.194-201, 2018. ,
Deep learning for acoustic echo cancellation in noisy and double-talk scenarios, in Interspeech, pp.3239-3243, 2018. ,
Statistical convergence analysis for optimal control of DFT-domain adaptive echo canceler, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.5, pp.1095-1106, 2017. ,
DNN-based residual echo suppression, pp.316-320, 2015. ,
Multiple-input neural network-based residual echo suppression, Proc. ICASSP, pp.231-235, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01723630
Frequency-domain adaptive Kalman filter for acoustic echo control in hands-free telephones, Signal Processing, vol.86, issue.6, pp.1140-1156, 2006. ,
Multichannel semi-blind source separation via local Gaussian modeling for acoustic echo reduction, Proc. EUSIPCO, pp.496-500, 2011. ,
Speech dereverberation based on variance-normalized delayed linear prediction, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1717-1731, 2010. ,
Generalization of multi-channel linear prediction methods for blind MIMO impulse response shortening, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.10, pp.2707-2720, 2012. ,
Multi-Channel Linear Prediction-Based Speech Dereverberation With Sparse Priors, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.23, issue.9, pp.1509-1520, 2015. ,
Neural network-based spectrum estimation for online WPE dereverberation, pp.384-388, 2017. ,
Robust speech dereverberation using multichannel blind deconvolution with spectral subtraction, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.5, pp.1579-1591, 2007. ,
Optimized speech dereverberation from probabilistic perspective for time varying acoustic transfer function, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.7, pp.1369-1380, 2013. ,
Combined weighted prediction error and minimum variance distortionless response for dereverberation, Proc. ICASSP, pp.446-450, 2017. ,
A consolidated perspective on multimicrophone speech enhancement and source separation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.4, pp.692-730, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01414179
Under-determined reverberant audio source separation using a full-rank spatial covariance model, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1830-1840, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00435807
Multichannel nonnegative matrix factorization in convolutive mixtures for audio source separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.3, pp.550-563, 2010. ,
Multichannel audio source separation with deep neural networks, IEEE/ACM Transactions on ,
URL : https://hal.archives-ouvertes.fr/hal-01163369
, Audio, Speech, and Language Processing, vol.24, issue.9, pp.1652-1664, 2016.
Semi-supervised multichannel speech enhancement with variational autoencoders and non-negative matrix factorization, Proc. ICASSP, pp.101-105, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02005102
Joint DNN-based multichannel reduction of echo, reverberation and noise: Supporting document, Inria, 2019. ,
Multichannel music separation with deep neural networks, Proc. EUSIPCO, pp.1748-1752, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01334614
Scalable audio separation with light kernel additive modelling, Proc. ICASSP, pp.76-80, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01114890
Librispeech: an ASR corpus based on public domain audio books, Proc. ICASSP, pp.5206-5210, 2015. ,
Roomsimove, 2008. ,
SDR -halfbaked or well done, Proc. ICASSP, pp.626-630, 2019. ,
, Speech Enhancement: Theory and Practice, 2007.
On adjusting the learning rate in frequency domain echo cancellation with double-talk, IEEE Transactions on Audio, Speech, and Language Processing, vol.15, issue.3, pp.1030-1034, 2007. ,
Adam: A method for stochastic optimization, Proc. ICLR, 2015. ,
, 2017 to 2020 and obtained the Ph.D. degree in informatics from the Université de Lorraine and Inria Nancy-Grand-Est
, ) doing research on robust speech communications and ambient sound detection and classification, Romain Serizel received the M.Eng. degree in Automatic System Engineering from ENSEM, vol.1, 2011.
, His research focuses on statistical machine learning for speech and audio signal processing, with application to audio source localization and separation, speech enhancement, and robust speech and speaker recognition. He is a founder of the series of CHiME, SiSEC and VoicePrivacy challenges. He was an associate editor for, Emmanuel Vincent is a Senior Research Scientist with Inria, 2004.
, 2002 and the M.Sc. degree in acoustics, computer science and signal processing applied to music (ATIAM) from the Université Pierre et Marie Curie, He worked as an audio software engineer at Inventel, 2003.
