Deep latent factor model for collaborative filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Signal Processing Année : 2020
Latent factor models have been used widely in collaborative filtering based recommender systems. In recent years, deep learning has been successful in solving a wide variety of machine learning problems. Motivated by the success of deep learning, we propose a deeper version of latent factor model. Experiments on benchmark datasets shows that our proposed technique significantly outperforms all state-of-the-art collaborative filtering techniques.
DLFM SP3.pdf (421.93 Ko) Télécharger le fichier
hal-02373934 , version 1 (22-11-2019)
Aanchal Mongia, Neha Jhamb, Emilie Chouzenoux, Angshul Majumdar. Deep latent factor model for collaborative filtering. Signal Processing, 2020, 169, pp.107366. ⟨10.1016/j.sigpro.2019.107366⟩. ⟨hal-02373934⟩
77 Consultations
481 Téléchargements
