Analysis on Boolean function in a restricted (biased) domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2020
Boolean functions are usually studied under the assumption that each input bit is considered independent and identically distributed. However, in the case of some stream ciphers, a keystream bit is generated by using a nonlinear Boolean function with inputs from a restricted domain. At Eurocrypt 2016, one such stream cipher (FLIP) has been proposed, where a Boolean function on n variables was exploited with inputs of weight n/2 only. Recently, Carlet et al. studied several properties of such functions and obtained certain bounds on linear approximations of direct sum in the restricted domain. In this paper, we observe that for a direct sum like f = g+h, the inputs to each sub-function g, h do not follow a uniform distribution in the restricted domain. In this regard, we study the properties of Boolean functions by considering a general probability distribution on the inputs. We further obtain several bounds related to the biases of direct sums. Finally, we obtain a lower bound on the bias of the nonlinear filter function of FLIP. Our results provide a general framework to study security parameters of ciphers over restricted domain.
Fichier non déposé
hal-02374194 , version 1 (21-11-2019)
Subhamoy Maitra, Bimal Mandal, Thor Martinsen, Dibyendu Roy, Pantelimon Stanica. Analysis on Boolean function in a restricted (biased) domain. IEEE Transactions on Information Theory, 2020, 66 (2), pp.1219-1231. ⟨10.1109/TIT.2019.2932739⟩. ⟨hal-02374194⟩
168 Consultations
0 Téléchargements
