A hybrid Lagrangian-Eulerian particle model 667 for reacting pollutant dispersion in non-homogeneous non-isotropic turbu-668 lence, Physica A Stat Mech Appl, vol.388, issue.8, pp.1375-1387, 2009. ,
Code Saturne: A Finite, vol.670, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01115371
, Code for the computation of turbulent incompressible flows -Industrial 671 applications, Int J Finite Volumes, vol.1, issue.1
A hybrid CFD RANS/Lagrangian 673 approach to model atmospheric dispersion of pollutants in complex urban 674 geometries, Int J Environ and Pollut, vol.64, issue.1-3, pp.74-89, 2018. ,
, , p.676, 2009.
, Stochastic downscaling method: application to wind refinement, Stoc Env, vol.677
, Res Risk A, vol.23, issue.6, pp.851-859
Turbulent dispersion with broken 679 reflectional symmetry, J Fluid Mech, vol.332, pp.141-156, 1997. ,
A PDF micromixing model of dis-681 persion for atmospheric flow. Part I: development of the model, application 682 to homogeneous turbulence and to neutral boundary layer, Atmos Environ, vol.683, issue.8, pp.1457-1469, 2005. ,
A PDF micromixing model of 685 dispersion for atmospheric flow. Part II: application to convective boundary 686 layer, Atmos Environ, vol.39, issue.8, pp.1471-1479, 2005. ,
Modelling of concentration fluc-688 tuations in canopy turbulence, Boundary-Layer Meteorol, vol.122, issue.3, pp.655-681, 2007. ,
On the two-dimensional mixing 690 region, J Fluid Mech, vol.74, issue.2, pp.209-250, 1976. ,
Wind simulation refine-692 ment: some new challenges for particle methods, Progress in Industrial 693 Mathematics at ECMI, pp.765-770, 2008. ,
, , 2011.
, lerian/Lagrangian approach to multiphase flows, Int J Multiphas Flow, vol.696, issue.3, pp.293-297
An application of the Langevin 698 equation for inhomogeneous conditions to dispersion in a convective bound-699 ary layer, J Roy Meteor Soc, vol.112, issue.471, pp.165-180, 1986. ,
Probability density function and Reynolds-stress 701 modeling of near-wall turbulent flows, Atmos Environ, vol.9, issue.1, pp.1691-1701, 1997. ,
How can we satisfy the well-mixed criterion in highly 705 inhomogeneous flows? A practical approach. Lagrangian Modeling of the 706 Atmosphere, pp.59-70, 2013. ,
On Lagrangian stochastic methods for turbulent polydisperse 708 two-phase reactive flows, Prog Energ Combust, vol.50, pp.1-62, 2015. ,
Statistical descriptions of polydisperse turbulent two-phase 710 flows, Phys Rep, vol.665, pp.1-122, 2016. ,
The PDF approach to turbulent polydispersed 712 two-phase flows, Phys Rep, vol.352, issue.1, pp.1-214, 2001. ,
Analysis of a PDF model in a mixing layer case, 1995. ,
, Proc. Tenth Symp. Turbulent Shear Flow, vol.30, pp.715-741
Wall-boundary conditions in probability density 717 function methods and application to a turbulent channel flow, Phys Fluids, vol.718, issue.9, pp.2632-2644, 1999. ,
Guidelines for the formulation of 720, 2014. ,
, Lagrangian stochastic models for particle simulations of single-phase and 721 dispersed two-phase turbulent flows, Phys Fluids, vol.26, issue.11, p.303
, Statistical fluid dynamics, 1971.
Mean-field/PDF nu-725 merical approach for polydispersed turbulent two-phase flows, Prog Energ, vol.726, issue.3, pp.315-371, 2006. ,
PDF methods for turbulent reactive flows, vol.11, pp.119-192, 1985. ,
Consistency conditions for random-walk models of turbulent 730 dispersion, Phys Fluids, vol.30, issue.8, pp.2374-2379, 1987. ,
Computations of turbulent combustion: progress and chal-732 lenges, Symposium (International) on Combustion, vol.23, pp.591-612, 1991. ,
Lagrangian PDF methods for turbulent flows, Annu Rev 735 Fluid Mech, vol.26, issue.1, pp.23-63, 1994. ,
On the relationship between stochastic Lagrangian models 737 of turbulence and second-moment closures, Phys Fluids, vol.6, issue.2, pp.973-985, 1994. ,
Turbulent flows, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00338511
Generalized random forcing in random-walk turbulent dis-740 persion models, Phys Fluids, vol.29, issue.11, pp.3582-3585, 1986. ,
Lagrangian statistical simulation of concentration mean 742 and fluctuation fields, J Clim Appl Meteorol, vol.24, issue.11, pp.1152-1166, 1985. ,
Uniqueness and universality of Lagrangian 744 stochastic models of turbulent dispersion, 8th Symposium on Turbulence 745 and Diffusion, vol.1, pp.96-99, 1988. ,
The Lagrangian 747 particle dispersion model FLEXPART version 6.2, Atmos Chem Phys, 2005. ,
Analysis of the incompressibility con-750 straint in the smoothed particle hydrodynamics method, Int J Numer Meth 751 Eng, vol.92, issue.4, pp.343-369, 2012. ,
Criteria for the selection of stochastic models of particle 753 trajectories in turbulent flows, J Fluid Mech, vol.180, pp.529-556, 1987. ,
Review and validation of MicroSpray, a Lagrangian par-756 ticle model of turbulent dispersion, Lagrangian Modeling of the Atmosphere, vol.757, pp.311-328, 2013. ,
Random walk models for 759 particle displacements in inhomogeneous unsteady turbulent flows, Fluids, vol.760, issue.6, pp.1639-1653, 1985. ,
Probability density function 762 computation of turbulent flows with a new near-wall model, Phys Fluids, vol.763, issue.5, pp.1410-1422, 2004. ,
Review of Lagrangian stochastic models for 765 trajectories in the turbulent atmosphere, 1996. ,
Numerical simulation of particle 767 trajectories in inhomogeneous turbulence, 1981. ,
