Guess Who's Coming: Runtime Inclusion of Participants in Choreographies
In Choreographic Programming, a choreography specifies in a single artefact the expected behaviour of all the participants in a distributed system. The choreography is used to synthesise correct-by-construction programs for each participant. In previous work, we defined Dynamic Choreographies to support the update of distributed systems at runtime. In this work, we extend Dynamic Choreographies to include new participants at runtime, capturing those use cases where the system might be updated to interact with new, unforeseen stakeholders. We formalise our extension, prove its correctness, and present an implementation in the AIOCJ choreographic framework.
