The design and application of upwind schemes on unstructured meshes, Aerospace Sciences Meeting, 1989. ,
Flow around a circular cylinder near a plane boundary, Journal of Fluid Mechanics, vol.89, issue.1, pp.33-47, 1978. ,
Análisis transitorio de la interferencia de flujo entre dos cilindros circulares en disposición tándem, Mecánica Computacional, vol.37, pp.1195-1204, 2018. ,
Scale-adaptive simulation of flow around a circular cylinder near a plane boundary, Journal of Applied Fluid Mechanics, vol.11, issue.6, pp.1477-1488, 2018. ,
Characteristics of the flow around two circular cylinders arranged in tandem: 1st report, Bulletin of JSME, vol.24, issue.188, pp.323-331, 1981. ,
Numerical investigation on flow around circular cylinders in tandem arrangement at a subcritical Reynolds number, Journal of Fluids and Structures, vol.24, issue.5, pp.680-699, 2008. ,
Re-examination of the effect of a plane boundary on force and vortex shedding of a circular cylinder, Journal of Wind Engineering and Industrial Aerodynamics, vol.80, issue.3, pp.263-286, 1999. ,
The ultimate conservative difference scheme applied to unsteady one-dimensional advection, Computer methods in applied mechanics and engineering, vol.88, issue.1, pp.17-74, 1991. ,
Large eddy simulations of flow around two circular cylinders in tandem in the vicinity of a plane wall at small gap ratios, Journal of Fluids and Structures, vol.76, pp.251-271, 2018. ,
Numerical simulation of flow interference between two circular cylinders in tandem and side-by-side arrangements, Journal of Fluids and Structures, vol.15, issue.2, pp.327-350, 2001. ,
A scale adaptive simulation model using two-equation models, Aerospace Sciences Meeting and Exhibit, 1905. ,
A scale-adaptive simulation model for turbulent flow predictions, Aerospace Sciences Meeting and Exhibit, 2003. ,
Two-equation eddy-viscosity turbulence models for engineering applications, AIAA Journal, vol.32, issue.8, pp.1598-1605, 1994. ,
Vortex shedding from a circular cylinder near a moving ground, Physics of Fluids, vol.19, issue.2, p.25103, 2007. ,
Influence of wall proximity on flow around two tandem circular cylinders, Ocean Engineering, vol.94, pp.36-50, 2015. ,
Interference between two circular cylinders; series of unexpected discontinuities, Journal of Wind Engineering and Industrial Aerodynamics, vol.2, issue.3, pp.255-270, 1977. ,
