Presiones debidas a viento en tanques de petróleo alineados en tándem mediante CFD, Mecánica Computacional, vol.XXXIV, pp.775-794, 2016. ,
A study of storage tank accidents, Journal of Loss Prevention in the Process Industries, vol.19, pp.51-59, 2006. ,
Computational Methods for Fluid Dynamics, 2001. ,
Buckling of short tanks due to hurricanes, Engineering Structures, vol.20, issue.8, pp.752-760, 1998. ,
Recommendations on the use of CFD in wind engineering. En J. van Beeck, editor, Proceedings of the International Conference on Urban Wind Engineering and Building Aerodynamics. COST action C14, 2004. ,
A 3-D finite element mesh generator with built-in preand post-processing facilities, International Journal for Numerical Methods in Engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
Performance of storage tanks in oil facilities damaged by hurricanes Katrina and Rita, Journal of Performance of Constructed Facilities, vol.21, issue.6, pp.441-449, 2007. ,
Buckling of vertical oil storage steel tanks: Review of static buckling studies. Thin-Walled Structures, vol.103, pp.1-21, 2016. ,
Some developments in turbulence modeling for wind and environmental engineering, Journal of Wind Engineering and Industrial Aerodynamics, vol.96, issue.10, pp.1537-1570, 2008. ,
On the use of the k ? ? model in commercial CFD software to model the neutral atmospheric boundary layer, Journal of Wind Engineering and Industrial Aerodynamics, vol.95, issue.5, pp.355-369, 2007. ,
Wind buckling of metal tanks during their construction. Thin-Walled Structures, vol.48, pp.453-459, 2010. ,
The prediction of laminarization with a two-equation model of turbulence, International Journal of Heat and Mass Transfer, vol.15, pp.301-314, 1972. ,
Wind loads on circular storage bins, silos and tanks: I. point pressure measurements on isolated structures, Journal of Wind Engineering and Industrial Aerodynamics, vol.31, issue.2, pp.165-187, 1988. ,
Improved k ? ? model and wall function formulation for the rans simulation of abl flows, Journal of Wind Engineering and Industrial Aerodynamics, vol.99, issue.4, pp.267-278, 2011. ,
Computational fluid dynamics study of flow around floating-roof oil storage tanks, Journal of Wind Engineering and Industrial Aerodynamics, vol.86, issue.1, pp.37-54, 2000. ,
Shielding effects and buckling of steel tanks in tandem arrays under wind pressures. Wind and Structures, An International Journal, vol.8, issue.5, pp.325-342, 2005. ,
Appropiate boundary conditions for computational wind engineering models using the k ? ? turbulence model, Journal of Wind Engineering and Industrial Aerodynamics, vol.46, pp.145-153, 1993. ,
Appropiate boundary conditions for computational wind engineering models revisited, Journal of Wind Engineering and Industrial Aerodynamics, vol.99, pp.257-266, 2011. ,
Experimental and numerical modelling of the three-dimensional incompressible flow behaviour in the near wake of circular cylinders, Journal of Wind Engineering and Industrial Aerodynamics, vol.96, issue.5, pp.471-502, 2008. ,
About Boussinesq's turbulent viscosity hypothesis: historical remarks and a direct evaluation of its validity, Comptes Rendus Méchanique, vol.335, issue.9, pp.617-627, 2007. ,
AIJ guidelines for practical applications of CFD to pedestrian wind environment around buildings, Journal of Wind Engineering and Industrial Aerodynamics, vol.96, pp.1749-1761, 2008. ,
A tensorial approach to computational continuum mechanics using object-oriented techniques, Computers in Physics, vol.12, issue.6, pp.620-631, 1998. ,
Development of turbulence models for shear flows by a double expansion technique, Physics of Fluids A, vol.4, issue.7, pp.1510-1520, 1992. ,
