MaxHedge: Maximising a Maximum Online - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce a new online learning framework where, at each trial, the learner is required to select a subset of actions from a given known action set. Each action is associated with an energy value, a reward and a cost. The sum of the energies of the actions selected cannot exceed a given energy budget. The goal is to maximise the cumulative profit, where the profit obtained on a single trial is defined as the difference between the maximum reward among the selected actions and the sum of their costs. Action energy values and the budget are known and fixed. All rewards and costs associated with each action change over time and are revealed at each trial only after the learner's selection of actions. Our framework encompasses several online learning problems where the environment changes over time; and the solution trades-off between minimising the costs and maximising the maximum reward of the selected subset of actions, while being constrained to an action energy budget. The algorithm that we propose is efficient and general that may be specialised to multiple natural online combinatorial problems .
maxHedge.pdf (441.59 Ko) Télécharger le fichier
hal-02376987 , version 1 (22-11-2019)
Stephen Pasteris, Fabio Vitale, Kevin Chan, Shiqiang Wang, Mark Herbster. MaxHedge: Maximising a Maximum Online. International Conference on Artificial Intelligence and Statistics, Apr 2019, Naha, Okinawa, Japan. ⟨hal-02376987⟩
32 Consultations
39 Téléchargements
